View Full Version : Can I get two of these batteries in my Small Bolt?
Turbo Dan-O
11-13-2011, 08:17 PM
http://www.hobbyking.com/hobbyking/store/__20425__Turnigy_nano_tech_1600mah_2S_25_50C_Lipo_ Pack_USA_Warehouse_.html I am sure I will need a good amount of weight up front running it on 4S and it looks like I can probably fit them but is this overkill? I know the 1000/1300mah will fit but just wanted to get you guys opinion on the big ones!
Dan-O
tim v
11-13-2011, 11:34 PM
i put a 2200 mah 3cell 40c no problem wouldn't go any bigger though..
Basstronics
11-14-2011, 05:26 PM
I wouldnt think two will fit. 2200 is a tight squeeze IMO.
I run a 1300 and thats just fine size wise. But Im running 3S
Turbo Dan-O
11-17-2011, 11:15 PM
Not looking to fit two 2200 3s. Just two 2s batteries.
lenny
12-03-2011, 06:42 PM
I can fit two PolyRC 3s1p 25c 2200mah in my bolt.
I just tested it with a water proof hatch modding,
And no tape and 1/2 tsp water in the hull in the sponge after 4 sets of lipos at 6 minutes runs.
I think the water came from the stuffing tube and flex shaft,
But the tube is cut to short to put a cap on or shrink wrap on.
Turbo Dan-O
12-04-2011, 12:49 PM
65109 I went with two 1300 2s Nano Techs. They fit great and I have plenty of room to move them around. I can't wait to see how it will run on 4s!
netik racing
12-13-2011, 10:02 PM
CAn we see the hatch modding i would love to not tape mine anymore...
lenny
12-13-2011, 11:08 PM
Ok hear are some pictures,
It just a blue peace of plastic with a bolt and nut and 6560265603656046560565606cooling tube peace and washer with rubber and black cap,
Ruff setup, But works good.
lenny
12-13-2011, 11:16 PM
More pictures,65607656086560965610
Their is 1/4"window seal around the hatch hull.
netik racing
12-13-2011, 11:32 PM
many thanks for the photo's....the only problem i have is that i have a 380l motor in mine so trying to anything more in the the hull is very hard....
but i have a thought that i might be able to make something up...
Cheers Paul
lenny
12-13-2011, 11:39 PM
Hi,
How does it run with the 380l motor ?
Do you run on 3s or 4s ?
I am using 3s and all stock but the prop, But what more speed,lol
lenny
12-13-2011, 11:40 PM
Have any pictures of yours ?
And setup.
netik racing
12-14-2011, 04:45 PM
And setup.
http://www.youtube.com/watch?v=DWYgmJGYfNc
its got a 2600kv 380l motor in it 40amp esc custom prop i made 3s 2200mah inline with the motor....
goes well... try 4s and was just insane more testing needed...jumping around bad....
will take some pic tonight
afishfool
01-01-2012, 03:50 PM
Ran my small bolt today 3s 30c fast motor burned up after 6 runs what would be a good replacement it was fast on the stock one but if I need new I want faster
netik racing
01-16-2012, 11:01 PM
HI Guy’s
So ive been getting a few email’s about my mini bolt so I thought I would do a small write up….
I got it as a rtr from hor on ebay I think it was like $180 delivered…
After having it out twice the motor died not from over propping but the cooling system blocked up…
So as a rtr I was a little disappointed with the top speed but im glad that the motor broke…
Firstly I upgraded the motor to a 380 long motor 2600kv.. the only thing I had to do is put the collet in my lathe and drill out the motor shaft size …(easy)
So I then put it back together the holes lined up on the motor mount so that made things easy….the shaft angle was not spot on but for then I wasn’t worried…so with the standard prop and standard esc it was ok bit for me still not fast enough.. now I was having a few problems with the servo mount moving…so after using 3 matchstick’s and some glue I fixed that issue..
Secondly I broke the prop to be expected because it was plastic. So I thought I better go the metal way. I looked at the octura range but I couldn’t be bothered balancing and stuff so I got a venom 32mm cnc prop and did one or two mod’s to it so it was more to my liking.
Lastly the stock ecs was getting very hot when I changed to the 32mm prop so I thought I better upgrade the esc I had a blown 60amp seaking there so I grabbed the water cooler off it got a 70amp (airplane) esc from hobby king and made it into a water cooled esc cheap for $30..now I have a rubber band on my controller so the trigger hold full reverse …on the upside the esc has soft start so it great for the boat….
What next I hear you say… well plans are for 4s with this motor I have tried it but it was uncontrollable I think the weight is too far forward so im going to get 2 2s pack’s and place them alongside the motor to get better weight distribution…also going to try and use the 4s I have and add a little weight to the back to the hull to see if that will work as well…then well you have to stay tuned for what happen next..
Would love to see 80kph out of it at the moment it’s about 60kph so away to go…..
Any suggestions are welcome as well…
6832868329
