View Full Version : New Stickers
TAMonti
11-11-2011, 09:16 PM
I received a new set of stickers from Pro Boat. What can I use to remove any surface debris from the hull?? Rubbing alcohol?? Thinner??
ejimbo4
11-11-2011, 09:30 PM
I used "Goo Gone" on mine and it worked great. I just peeled of the decals and put the goo gone on everything that was left over,saturated it real good but not sloppy and waited 5 minutes and it wiped off with no problem.
TAMonti
11-11-2011, 10:04 PM
I used Goo Gone to remove the sticker residue, but I just wanted to remove any other substance that might make the new stickers lift.
ejimbo4
11-12-2011, 01:50 PM
I used windex and then alcohol after the goo gone.
Diesel6401
11-12-2011, 03:38 PM
A little bit of wd-40 on a rag, then a little rubbing alcohol.
Darin Jordan
11-12-2011, 11:53 PM
I use Lighter Fluid for removing tape and sticker residue. Works fantastic.
