View Full Version : what my boat hopping on stright run
kennyrach
11-09-2011, 08:05 AM
Hi all i just ran a 28" balsa wood boat that i build from Peells plan .the boat hop a lot when running straight . see video http://youtu.be/3R6GPvO3puY here the set up i am using In runner Brushless Motor B3656 KV2600
Aluminum adjustable stinger drive with 4mm cable set
Zipps kit 50 Amp Brushless Motor Controller
2S 7.4V 4200 mah lipo battery pack
martin
11-09-2011, 11:52 AM
Move the cg foward to around 30% of the hull length in from the transom, it looks like you also have the stinger up to much at the prop end. Set the stinger level.
kennyrach
11-09-2011, 11:56 AM
Move the cg foward to around 30% of the hull length in from the transom, it looks like you also have the stinger up to much at the prop end. Set the stinger level.Yes your right the stringer is high but their no adj for so i make something to level it and what cg ?.I have the motor at at 3/4 of boat starting from transom to front
martin
11-09-2011, 12:02 PM
Cg is centre of gravity, the hull should balance at around 30% of its length. Example if the hull is 28" long then 30% would be 8.4", so the boat should balance 8.4" in from the transom (rear of hull). You can then fine tune the balance from their but 30% is a good starting point.
sundog
11-10-2011, 10:01 PM
Does this boat have trims tabs? Tabs can help prevent porpoising like that.
Alexgar
11-10-2011, 11:09 PM
Cog, trim tabs and put your strut angle down a bit just my opinion
Namba328
11-12-2011, 03:11 AM
Pictures????
kennyrach
11-17-2011, 08:46 PM
no trim tab on it i may try and see it that help
kennyrach
11-17-2011, 08:59 PM
boat has battery move up front it still came out of water at half speed .will try next week with the stinger drive angle down a bit and with Feigao 540L "Long" Brushless 540 11L 2,326 RPM / Volt 5mm Shaft motor.to run on two 2S 7.4V 4200 mah lipo pack wire in series
kennyrach
11-17-2011, 09:02 PM
what size you think i need and how far out off back of boat .me thing 1 1/2" off back and 1 1/16 from bottom of boat
Alexgar
11-17-2011, 09:46 PM
I thInk the bottom of the strut should be flush with the bottom of the sponsons
sundog
11-17-2011, 10:30 PM
I'd go with 2" wide by 1-1/2 to 2" long tabs. Put them 1/16" (2mm) above the bottom of the hull (not flush). Adjust if necessary. Should tame it right down.
Alexgar
11-17-2011, 10:57 PM
sun i was talking about the strut i started with mine flush and level and angled down just a little when my apparition was nosing up and bouncing
sundog
11-17-2011, 11:52 PM
Yep, I'd try adjusting the strut down first. But if that won't fix it, tabs will. :thumbup:
kennyrach
11-20-2011, 09:52 AM
Thank all for the info i will try all and see thank
ashcossie
05-11-2012, 06:59 PM
sorry new to boating but when u say adjust the strut which bit on the boat do u mean same with the tabs
cheers
kennyrach
05-12-2012, 11:07 AM
What i found on my boat is strut angle down will bring boat bow down and strut angle up will bring bow up ,the tabs help the boat run even .You can try and see it this help
