View Full Version : Turnigy 120 esc cap temps ?
lenny
11-01-2011, 09:05 PM
Hi,:tiphat:
I have a 36"shock wave that is fe now,
My esc cap temps are 160f and up some times is that to hot for them ?:unsure:
Boat setup is,
36"Mono, All stock hardware except for collet and prop, Motor is a Feigao 9xl 1898kv,
:thumbup1:
Now I put a 4074 2200kv motor in it now and more caps,
Runs a lot cooler and better now,
Also using a x646/3 prop now.
Esc is a Turnigy marine 120a and programed setting are 2 4 3 3 with card,
Cell are Turnigy 4s2p 40c to 50c 3000mah and 5.5 bullets all the way.
Ran today with a p230 for 4 minute runs and gps at 42.5mph,
All temp cool 98f, Just caps where ,160f, 198f.
Thanks for any info.:beerchug:
Lenny D
Make-a-Wake
11-01-2011, 11:36 PM
Caps are fine there in my opinion.
lenny
11-02-2011, 12:20 AM
I was testing props today and was not sure about the caps,
Did not want push them to far.
First time I ran the boat it ran good but had a wobble side to side at top speed with a x442 at 36mph.
I thought the cells needed to be moved lower to center of hull to stop the wobble.
But I had to go forward to because of the rails in the way,
The boat ran ok maybe a little wet today.
I want to test some more and prop up some,
Will also move cell back to the sides of the hull and see what happens.
lenny
11-02-2011, 09:52 PM
What is temp limit for caps ?
Ran it today with m445 for 3 minutes got 41.8 mph gps,
Temps were, caps 227 F, esc 98 f, motor 115 f , cells 80 f.
Cells were Turnigy 4s2p 25c to 35c 5800mah.
Make-a-Wake
11-02-2011, 11:23 PM
Cap limit is normally 105* Celsius.......................you were real close. I'd prop down to an x442.
lenny
11-02-2011, 11:57 PM
OK thanks, That good to know.
It was faster with a p230 at 42.3mph and caps were 170f,
I think the p230 is the winner, Have to test with one some more.
The cells were 110f , esc 90f, Motor 98f.
TheShaughnessy
11-03-2011, 12:10 AM
I'd add some. I added two and they don't get over 120
lenny
11-03-2011, 12:34 AM
Ok that may be a good thing to do.
I have some caps that came in a box with other stuff I bought.
What kind of caps do I need ?
How do I do it ?
Have any pictures on how you did it ?
ejimbo4
11-03-2011, 12:11 PM
Found this two pages back...
http://forums.offshoreelectrics.com/showthread.php?29754-How-to...-add-capacitors-to-an-esc-(seaking-180a)&highlight=esc+caps
rc2266
11-08-2011, 08:33 AM
Do you have trim tabs, if so might need adjusting
lenny
09-30-2012, 01:46 PM
Hi,:tiphat:
Looking to try my setup on 5s using the 4074 2200kv motor and x646/3 prop.
Do you guys think it will be ok ?
Fast Guy
09-30-2012, 03:59 PM
I have the SeaKing 120a ESC and the cap temps were in the high 100's like yours. I removed the stock caps and installed 2 caps that I got from Off Shore Electric. Cap temps are now around 120f with no changes to the power system.
Rubycon Low ESR Capacitor
(http://www.offshoreelectrics.com/proddetail.php?prod=ck-cap-35v-1000)
