View Full Version : Installing OSE Upgraded flex cable........
TAMonti
10-29-2011, 09:31 PM
How do I remove the stock Teflon tube???
de-pro
10-30-2011, 10:59 AM
Take the motor out. with the flexshaft press against the tube from outside inwards
TAMonti
11-11-2011, 10:05 PM
Anyone know what size Allen wrench fits the set screw in the drive dog on the OSE cable??
LarrysDrifter
11-11-2011, 10:31 PM
Probably a 1.5 or 2mm. Go to your LHS and get a set of allen drivers. Standard "L" shaped allens wear quickly and easily strip.
11-11-2011, 10:32 PM
.050 http://www.offshoreelectrics.com/proddetail.php?prod=dh-dyn2910
TAMonti
11-11-2011, 10:42 PM
Thanks!!
I'm guessing Steven is correct. The set screw is MUCH smaller than a 2mm or even a 1.5mm. (Which I already tried)
LarrysDrifter
11-11-2011, 10:50 PM
Thats cool. I didnt know OSE sold those. Sorry, Steve.
11-12-2011, 07:23 AM
Thanks!!
I hope I'm correct.:smile:
If not I have about 1000 or more worth of cables out in the market that we have been using the wrong driver on. :roflol:
Another words i can assure you that the oc6dmm drive dog takes a .050 driver.
The larger drive dog, oc6dm takes a 5/64 driver. I will add that info to the drive dog info.
Also I've never had good luck with the smaller L shaped allen wrenches with small grub screws. they usually just strip the screw. The larger stuff they would just fine on.
