View Full Version : what prop next?
the savy fluxer
10-29-2011, 08:50 PM
hey guys i have a prop question for ya . i have a 32" pursuit with a 2000kv 4074 Tacon motor,180 amp turnigy ecs, 2 4500 mah 5s lipos in parellel and a x642 prop. im hitting 55 mph and i want to take it to the next level with a prop change.
all my electronics are ice cold not even a little bit of heat. what i would be the next 2 sizes up in prop from the x642?
thanks
and yes i already know this is fast enough and i should not push my luck, but i have too.:flashfire::nono: ya know.
thanks
Make-a-Wake
10-29-2011, 09:07 PM
I cant believe you havent burned it up yet on 5s with a 642...........................
10-29-2011, 09:48 PM
Next up is probably an m545 or m645......:scared:
egneg
10-30-2011, 09:23 AM
I agree.
Drax21
10-30-2011, 09:42 AM
thanks
That set-up should take an M645 easily. I know diesel's does on a 2200kv Leopard on 4s so a 2000kv Tacon should be no problem on 5s. Just test it for a minute then bring it in, if all is well carry on. Don't forgot to post a vid!!
Make-a-Wake
10-30-2011, 10:10 AM
Your electronics are cold cuz you live in BC, i'm not being negative, i just think you have maxxed it out, i hit 59 in my Pursuit with a 2150kv Leopard with an x442on 5s......................you're runnin an x642. Certainly try it if you must but i bet with a 645 its slower than the 55 you hit.
the savy fluxer
10-30-2011, 03:51 PM
thanks guys
