View Full Version : New Stiletto..Painting, propping and mods! (Let's race!)
awall
10-25-2011, 10:45 PM
Just got my Stilleto today...now in paint:olleyes:
Marked off my proposed battery tray mod and new 1/8 ply lid. Lower profile..easier taping. Post pics as I do it.
62783
Up next...sponson sharpening...lightening as best you can on this RTR...Prop tests. LET'S RACE!!!
:cool2:
YOU GOT SUGGETIONS!!! LET'S HER IT!!!!!!!!!!!!
Griff
10-26-2011, 06:42 AM
good stuff keep us posted
awall
10-27-2011, 12:51 PM
Still painting! I pick to difficult of schemes. I'm trying to match the paint on my new mysyic cat.
awall
10-27-2011, 09:14 PM
Well, went started a new hatch cover mod. 1/8 ply sealed. 3 pieces as shown. Front and rear smaller pieces will be epoxied with the middle piece being the new hatch. Way easier to tape over stock, plus the top of the cover will end up around 1/8- inch lower than stock plastic (no cable rub).6287762878
awall
10-28-2011, 05:18 PM
62929
Front and rear ply epoxied in and bondo'ed. Some sanding then I will paint everything.
awall
10-28-2011, 08:09 PM
62934
Painted hatch on boat. Waiting to dry...and that's the hardest part for me.:blink:
barmonkey
10-28-2011, 11:01 PM
I like your mod idea. I was thinking of doing something similar...but actually raising the the battery box walls so they are even with the front radio box. This way the control lines are under the lid.
One question...when you cut the walls down, is there a gap between the fiberglass at that point?
Keep the pics coming!
FighterCat57
10-28-2011, 11:32 PM
While you're making mods, consider removing the cables and using a waterproof servo (http://forums.offshoreelectrics.com/showthread.php?29134-Eliminating-that-annoying-cable-on-the-stiletto...) at the rear. I've done this and really like the difference in control.
That's a great modification for the hull hold. I've been trying to figure out ways to keep mine sealed. Perhaps it's time to fabricate a new hatch. Love that idea!
Griff
10-29-2011, 12:43 PM
all great ideas, these will give me plenty to do over the winter
awall
10-29-2011, 01:50 PM
630056300663007
Thanks guys. I'm really liking the mod. Cable clerance is good now.
Barmonkey - I took about 1/8 to 3/16 off the top edges of the compartment and there was no gap between the fiberglass inner and outer walls. Everything was good and solid.
Fightercat - Yeah I've been toying with the servo in the back mod. If I did that I'de also look into moving receiver into battery box. Probably will do that later on. I just want to get her on the water.
awall
11-08-2011, 05:23 PM
636746367363672
Almost finished. Needs some lettering and adjusting. I did the copper shaft tube mod and will put my modded x642 on it.
