well, I tried binding a new hkt6a RX to my TX because the old one suddenly lost range.
everything was working perfectly, I removed the bind plug after binding and everything was working fine. I unplugged the batt and plugged it back in, the LED blinked and went out, strange. so i tried it with a servo and same thing.
I tried it with a GWS be-found that beeps when there is no signal.
it beeped on plug in and then nothing, but the power LED on the be-found was still blinking, showing low voltage (i was using a 6V rx pack, it was at about 5.5v or so.)
i unplugged everything and went for broke, plugged the RX pack in backwards, it worked, surprisingly.
then I plugged in a servo and the LED went out again.. ugh.
I bound to another RX (same type) and had the exact same problems.
I then proceeded to bind the two RX's to another TX, they both worked fine.
I tried the same procedures with a third RX, same thing.
I just don't understand how binding to a different TX (that was working about 2 weeks ago, last time I used it) would make the RX do this, any ideas?
