View Full Version : Turnigy 120 esc only runs for 30 secs
haggis
10-22-2011, 03:27 PM
My turnigy 120 ESC only works for around 30 secs then cuts out
after that it barely turns the motor over for about 5 secs then cuts out again
does this with my overlander motor and a brand new turnigy on 3s
any ideas?
Boaterguy
10-22-2011, 08:09 PM
could be an LVC problem
try charging the pack (i'f you're running it out of the box)
if not, perhaps disable the LVC but be careful about runtime so you don't overdischarge your packs
carlcisneros
10-22-2011, 08:21 PM
also, if you are running like 20C packs, switch over to at least 40C packs.
Boaterguy
10-22-2011, 10:20 PM
what he said.
the lower C rating packs (lower discharge) will dip in voltage under load, thus triggering the LVC.
+ they will puff up and/or worse if you draw too much from them.
