View Full Version : How to... add capacitors to an esc??? (seaking 180a)
Drax21
10-19-2011, 07:51 AM
Anybody got any pics of a seaking esc with 6 capacitors or know how to?
tiqueman
10-19-2011, 08:28 AM
Heres how I did mine. I think you can also just tack one onto each existing cap. Just be sure to match the polarities. The new ones come w/ 5 caps. The 4th and 5th are split between connection points of 1 to 2 and 2 to 3.
Browning
10-19-2011, 08:36 AM
Here's a couple shots of mine. The final step was to heat shrink the capacitors together, I can't find the final pic though, sorry ...
62525 62526
Drax21
10-19-2011, 10:57 AM
These are great guys. At least I have some idea of what I am doing now. Thanks
Browning
10-19-2011, 11:15 AM
Anytime, glad to help. Here are a couple more pics of the steps, hope they help..
Good luck !
625316253262533
Drax21
10-19-2011, 12:11 PM
Good luck !
625316253262533
Where did you get the card with loads of holes in?? What is it made of?
Browning
10-19-2011, 12:17 PM
It's just a small plastic circuit board that I get from Sayal hobbies http://www.sayalkits.com/CatalogContacts.asp. I'm sure you can get them from Radio Shack or The Source as well. Just about any electronics place sells them.
Drax21
10-19-2011, 12:23 PM
Of course it is :doh: Just bought 2 off ebay. I have a couple of escs to do. Thanks
driftah
10-19-2011, 12:32 PM
you can also get the same caps as factory off ose here and just parallel them off the original solder points underneath then shrinkwrap etc..easy peasy
JackBlack26
10-19-2011, 12:49 PM
I did mine the same way as Tiqueman, except I used perforated board to provide the caps with a little more support.
tiqueman
10-19-2011, 01:44 PM
thats how Im doing my next set.
Thats a good improvement as mine are easy to bump and push all over. Sometimes I knock intot hem and push the shrink wrap out of whack. eh, it was the first one I did. I saw the idea and liked how they were connected. It works well into you need to put it into a confined area (top to bottom) then the wires gave me some trouble from where I tapped into it. You lose a lot of flexibility. But, it works perfectly.
Actually Im setting my next one up like the new ones w/ 5.
properchopper
10-20-2011, 10:42 AM
Here's two applications using the Etti cap board :
On a P-Sport FE 30 :
62559
On an IB 34 ( wires attached on top of board to allow for hatch clearance - tricky to solder)
625606256162562
If you go this route, be sure to insulate the bottom of the board ( used G-10 & some electrical tape)
62563
Drax21
10-23-2011, 02:36 PM
Hi guys so I have the extra caps. I see no negative or positive signs on them just one wire is long the other shorter. Do they have a + and - or do you just keep each small wire in line and each long wire. BTW I have never added caps to anything before.....
LarrysDrifter
10-23-2011, 02:47 PM
There is a - on the side of the cap with the gray stripe. Usually, the gray stripe is always negative.
Boaterguy
10-23-2011, 03:44 PM
yep, the gray stripe is negative.
if there isn't one, the shorter one is negative, just like LED's
Drax21
10-24-2011, 07:51 AM
Thanks guys all sorted, hows this look? 62709627106271162712
I just paralleled them off each other, bit fragile but should be fine. I have wrapped them in heat sink too.
