View Full Version : can my leopard 4074 2200kv run 5s?
dana
10-15-2011, 02:36 PM
just wondering….
Boaterguy
10-15-2011, 04:25 PM
44K rpm unloaded, that's alot.
I'msure the motor would be able to take the voltage but would draw LOTS of amps and alot of heat would be created. Possibly a SAW setup.
CornelP
10-15-2011, 04:55 PM
Works ok, I did a 6min race on a 5S Nanotech 4500mA (30" mono, 38mm prop). A bigger prop will get you to cooking temperature for anything longer than a saw straight...
dana
10-15-2011, 06:00 PM
well on 4s i run m445. if i switch to an m440 will be better?
Rumdog
10-15-2011, 06:51 PM
Yeah, but it probably wont yield higher speed.
stadiumyamaha
10-15-2011, 09:51 PM
I wouldn't run it on 5s. I run 200kv motors on just about everything with a x642 and get low to mid fifties. Also try running 4s2p. Everything stays cooler and les amp draw.
Make-a-Wake
10-15-2011, 10:10 PM
Here's mine on 5s.................checked temps after the run and they were in the normal range.
yplfI5a4sNk
JIM MARCUM
10-16-2011, 03:41 PM
Ran my Miss Geico with a Leopard 4074 2200at the Legg Lake SAWs this weekend (Oct 14-16) with 4S2P and hit 52 MPH on the first pass, and hit a turtle on the pass back. 5S2P would have been a bit heaver (and is over the P class limit), but might have put a bigger dent in the turtle. Score: Turtle 1; Miss Geico 0. JIM
JIM MARCUM
10-16-2011, 03:42 PM
Ran my Miss Geico with a Leopard 4074 2200 at the Legg Lake SAWs this weekend (Oct 14-16) with 4S2P and hit 52 MPH on the first pass, and hit a turtle on the pass back. 5S2P would have been a bit heaver (and is over the P class limit), but might have put a bigger dent in the turtle. Score: Turtle 1; Miss Geico 0. JIM
dana
10-16-2011, 05:21 PM
im only getting 50mph no matter what i do when running 4s2p. its a mean machine hull
MORIDE
10-16-2011, 07:02 PM
JIm, what prop are you running on your MG with the Leopard 4074 2200?
JIM MARCUM
10-17-2011, 02:29 PM
62396623956239662395I was running an Octura X645. I bought the Miss GEICO hull only then the Pro Boat drive & strut. With a 4S29 config you can run a X648 x457 with my setup &a good speed controller. I used a SEAKING-180. Add more capacitors & you will have a better safety margin. Mounted a rudder w/H2O pickup on the Port sponson. It was on it's maiden run when on the return pass it hit a turtle 35" short of the SAW finish line, went airborne & crashed 10" from the finish lights . Impact ripped the rudder mounts off the sponson & the crash at 52+ (we'll never really know) impact split a 6" long section out of the Port sponson. See attached pics. I should have reinforced the starboard transon. But, they REALLY NEED to add more fiberglass on the hulls at the joint seams because a lot of guys have had their Miss GEICOs split open after minor impact crashes. ARE YOU LISTENING PRO BOAT!!! JIM
MORIDE
10-17-2011, 02:42 PM
Ouch!
Thanks for the reply. How do you add capacitors and can it be done on the Seaking 120? I am running stock motor SK 120 5S Gens Ace 40C 5000, detongued X642, I do run my strut lower that most here, but runs 47.1 MPH. I am just curious about the process of adding capacitors. I did like your offset rudder mod, did it help in the turns?
JIM MARCUM
10-17-2011, 04:37 PM
My SEAKING 180 was stock. You can buy caps here in the OSE parts section. I bought some but have not installed them. Check the forums on ESC & other elec links for installation help. Or just buy the 180. JIM
ecoovert
10-20-2011, 09:07 PM
Ran my Tacon 4074 2150kv. motor with a 180 amp esc. on 6s with an x442 prop with no problems. Temps never got above 119 degrees on my motor. Can't wait to try my 4082 setup.
