View Full Version : MiniMono metal prop upgrade?
vans552
10-11-2011, 02:42 AM
Does anyone know a good metal prop for the Aquacraft minimono? I saw that octura has a couple that are the right size but im not for sure , but any suggestions?
stock prop is 30mm two blade frp prop with a 1/8(3.2mm) prop shaft
Alfa Spirit
10-11-2011, 02:50 AM
Tenshock CNC props
vfrman40
10-24-2011, 12:24 PM
which octura prop would be recommended
chirotray
10-26-2011, 06:33 PM
I've got the y531 on mine. (purple plastic) After I get my issues worked out I may try a x432 just to see how it reacts.
pculton4
12-21-2011, 11:51 AM
I just put an Octura x432 on mine with a bullet nut. It makes a huge difference in the acceleration. Im not sure about the top speed but Im guessing its faster. I cant even get close to opening this thing in my pool and havent been to the pond yet.
flyingjunky
12-23-2011, 06:28 AM
Just ordered the x432 also for this and i just switched out that junky esc. for a 35 amp watercooling. I have the esc. already installed and i can notice a huge difference.
pculton4
12-23-2011, 08:39 PM
What brand of ESC did you go with? I would be interested in changing mine out also. Thanks.
iratner
12-23-2011, 09:36 PM
I am using an Octura 430 prop and the shorter Mini-Rio rudder. I also removed the turn fins as they are unneccessary.
Overall, once you replace the ESC and the drive shaft, it's a great boat!
flyingjunky
12-23-2011, 10:22 PM
What did you replace the drive shaft with??
flyingjunky
12-23-2011, 10:25 PM
http://www.hobbypartz.com/seaking35aboat.html have it in my small bolt and no issues so far
Brushless55
12-24-2011, 06:50 PM
Anyone run a prop bigger than 32mm?
pculton4
12-27-2011, 10:34 AM
Was that ESC easy to install? I have big hands and Im not very handy with these little boats?? I would also like to know what drive shaft was used by the other person who posted on here. Its not a good sign when they include an extra shaft with the boat!! Thanks guys!!
pculton4
12-27-2011, 10:54 AM
I dont see the wire that runs from the esc to the receiver in the picture of the 30 amp ESC from china. Thats what scared me. I need a direct replacement. If Im going to have to modify any parts I will be screwed!!
iratner
12-29-2011, 09:07 PM
Change the drive shaft to an Octura .098 shaft. You will need to find a drive dog that will fit both the boat and the shaft as the one that comes with .098 will not fit the boat.
pculton4
12-29-2011, 09:14 PM
Thank you for the info. Im actuallly sending the boat back to Hobby Services tomorrow. I put the battery in yesterday and the ESC caught fire. I had to run outside and rip it out. Hopefully they will send me a new one asap.
flyingjunky
01-22-2012, 07:20 PM
new 35 amp. water cooled esc., octura 432, trim tabs pushed up and fins sharpened. This minimo will do wheelies!!!!!!!!!!!!!!!! Hauls #$@!!!!!!
Brushless55
01-22-2012, 08:21 PM
any ideas of how fast it is now?
30-35mph?
flyingjunky
01-22-2012, 08:35 PM
30-35mph?
I would say 30-35 is about in-line. The most impessive part is the acceleration!!!! Instant speed.
pculton4
01-23-2012, 12:04 PM
What ESC did you switch to? I will need to get a new one for my old Mini. The office sold me a new Mini and is also sending my old one back with it!
bluznbeers
03-16-2012, 10:15 AM
Have a stock one and put a 435 prop on it - haven't tried it yet. Will let you know.
bluznbeers
04-11-2012, 08:35 PM
435 prop is excellent on the Minimono. It gets up on plane much faster (instantly actually) and the speed is noticeably faster. (Sorry no GPS because it wont fit in that little hull) Temps in cold spring lake water were: Motor 68, ESC 80 and battery was at 100 and change. The piano wire did let go once but I just re-soldered it and it has been good since.
Brushless55
06-04-2012, 03:18 PM
sounds like a x632 could kick some tail on this little mono!
smrdmr
07-18-2012, 10:38 AM
Are you running 2s or 3s?
bluznbeers
07-18-2012, 11:49 AM
It only runs on 3s
3b3b
07-20-2012, 09:44 AM
I'm using a TFL X430. $9 @ Kintec
Capt'n Crash
04-09-2017, 01:44 PM
How do you like the performance? I just purchased a TFL X430 for my Minimono.
Very nicely made little metal prop.
I'm using stock motor and 20a esc.
Capt'n Crash
05-15-2019, 10:51 AM
Reviving an old thread for those who may be interested.
When my TFL X430 arrived I didn't like the fit on the drive dog so I never tried it. Recently I purchased a few props from Doctorprops to try on various boats including a detounged stainless steel 32mm Naviga 2 blade. His props are beautifully crafted and this one fits the stock Minimono driveshaft perfectly. I'm hoping for a bit more speed with less amp draw from this prop.
jfrabat
05-17-2020, 02:43 PM
Reviving an old thread once again... I decided to revive my Minimono. My son had fried the ESC from using it in salt water, so I replaced it with a Hobbywing 30A watercooled one. Motor is stock. My son managed to freeze the motor from corrosion, but I managed to bring it back to life. Bought a 30mm 1.4 CNC and an Optura X432 for it to try out, bought a 1/8 bullet nut and sharpened the turn fins. We will see how it runs. May need to get me another micro FE to race my son!
Froggy
06-17-2023, 03:10 PM
Just put a 3219 Oxidean marine prop on mine too much for it, when I go to full throttle in comes out of the water like football thrown by an NFL quarterback lol going to prop down to 3019 I think will be the ticket for me.
