View Full Version : Holy Meat Cleavers Propman!
FighterCat57
10-09-2011, 06:21 PM
I was sent these as samples from a manufacturer and WOW. :w00t:
The pair sizes range from 52 - 55mm and they are 1.8 pitch I believe.
What kind of setup would these be good for? I can't imagine spinning up a pair of these on a Genesis size hull!
Curious how to calculate these bad boys. Perhaps they might be for a larger, say 55" hull? Maybe for my 57" Arrow Shark Project? :confused2:
61896 61897
Anyone have some good working knowledge of the 3 blade props in this size range?
mm123521
10-09-2011, 06:36 PM
Ben,
I am running a twin 6S, rigger.
http://forums.offshoreelectrics.com/showthread.php?28779-Twin-6S-Rigger-89.5MPH-Video
I just bought (one hour ago) a pair of 50 MM X 1.7 (3.3 inch pitch), 2 blade, props from the prop shop in UK.
At 38,000RPM loaded, these should give me a little under 100 MPH @ 15% slip.
Right now, I am using X457's (3.14 inch pitch) cut down to 52MM and I am getting 93 MPH. (nothing is getting hot, so far).
Hummm, a pair of those, 52MM x 1.8 (3.66 inch pitch) would give 110 MPH under the same conditions as above.
That might be the next step for me?
How much for a pair- one right hand and one left hand???
Mark
FighterCat57
10-09-2011, 06:49 PM
I suppose I could sell a pair, but really I'm curious how to calculate the application on these. That's a pretty sweet running rigger!
millzee
10-09-2011, 06:52 PM
How do you recon twin 1717's in a 42 sprint cat would spin them?
FighterCat57
10-09-2011, 06:57 PM
I don't know, I'm not sure how to calculate the load on them. Just a guess though that they would move a ton of water.
Anyone know how to calculate the load on these? There's a ton of props in FECalc, but none that I can see match up with the sizes of these.
ray schrauwen
10-09-2011, 08:50 PM
I would like a couple in left rotation.
What Aluminum is it?? CMDI used 7075 and the R2 hobbies cnc props must be 6061 from what it looked like after 2 runs... Dings & little bends etc...
Get them to use proper 7075 aircraft grade or they are disposable fairly fast.
FighterCat57
10-09-2011, 09:00 PM
Nice Avatar!
I'll ask. It feels like 6061, but I'll have to find out for sure. Thanks for bringing it up.
FYI- this isn't a sale thread! lol... I'm really looking for a way to calculate amp draw and determine the best application for them.
FighterCat57
10-09-2011, 09:20 PM
Confirmed 7075
6BOOST
10-10-2011, 01:56 AM
Thats easy, put a pair of each in with my motors and I'll test them on my eagle tree for you ;) :lol: I should have at least 3 twin engined setups, these would have been perfect for a twin 1717 mono, but I missed out on the mount on here a few days ago, I even had 4 of them to burn up for you too:banana:
carlcisneros
10-10-2011, 10:00 AM
Ben, those look like copies of the ABC props.
check their site www.abcprops.com and check out the prop chart section and locate the props with the same diameter.
a good place to start anyways.
FighterCat57
10-10-2011, 10:13 AM
Lol... they have a "cleaver" series there! Never looked at their props before.
I have quite a bit to learn about prop sizes and styles, that list made my eyes cross.
If I can make a match, I think the ABC props are listed in FE Calc. That would answer my initial question. =)
carlcisneros
10-10-2011, 08:54 PM
Ben, only SOME of the ABC props ae in the FE calc. I am in the proccess of adding some more this week.
Boaterguy
10-13-2011, 09:00 PM
Twinline T600's on either, send them for my DF 45
What do you mean by calculate load? i've never seen load numbers on props before.
ray schrauwen
10-13-2011, 09:16 PM
Confirmed 7075
sweet!
