View Full Version : Leopard 3674 2200KV amp draw?
riggerhunter
10-06-2011, 06:49 AM
Can anybody that has used a leopard 3674 2200kv motor on 4 cell lipo tell me what they found to be the amp draw? I would like to put one of these motors in a Miss Geico
when they finally get back in stock. Has anybody done this yet? I understand that there are a lot of variables with props etc. but just looking for the ball park figure to put the right
speed control for this boat. Thanks for your help guys.
jcald2000
10-06-2011, 07:49 AM
180 to 240 amps controller.
riggerhunter
10-06-2011, 07:52 AM
Thanks for the quick reply.
Make-a-Wake
10-06-2011, 08:16 AM
Propped correctly that motor will pull in the 80-100a range. You can run it with a T120 or SF120 if you like............some folks are going to the T180 for the ectra room.
riggerhunter
10-06-2011, 11:59 AM
Thanks for the info. I don't want to sound to new at this but what kind of ESC is the T180 (is it a turnigy?) Right now what I am running is a rigger insanity with the UL1 set up and ESC (60amp) 5000 4 cell lipo's. So I am not really familiar with anything else, just what I have been reading on the threads. I don't know what to buy that is a good ESC with out spending a lot of cash. I have read a lot of the seaking and turnigy ESC's that seem to go bad right away if they work at all. I also believe that I would have to run bullet connectors (8mm?) instead of the dean's because they can only go up to 60amps? All the info I can get will help and I really appreciate the feed back from you experienced guys. Thanks, Bob Jr.
Make-a-Wake
10-06-2011, 01:35 PM
No, bad info on the turnigy/ seakings. At 49 bucks a pop, the t120 is by far the best valuebout there. I must have 6-8 of them and they are darn near bulletproof even on 6s. Check hobbyking for the in stock amount, only 49 bucks!!!
10-06-2011, 01:52 PM
I'm running my 3674 at over 100amps. i would recommend a seaking 180.
Make-a-Wake
10-06-2011, 03:21 PM
In these decisions, it comes down to personal preference. I ran a 4074 2200kv for 6 months with a Turnigy 120a. I wanted the 120 for another boat so i bought a 180 for more room, especially if i wanted to prop up a bit more. My point is, the Turnigy Esc is a great one at a super price, go with a 180 if you are more comfortable that way. If you run an x440-x442 which is the best range for that motor on 4s, then the t120 will work based on personal experience and zero problems doing it.
Diesel6401
10-06-2011, 03:49 PM
Nothing wrong with the swordy 200s. Smaller then the 180's! I like them a lot, just make sure you waterproof the esc... I was running a abusing a seaking 120 with a 4074 1774 and a lot of prop lol... Finally I pushed to hard and killed her, but darn she took a beating. The seakings are amazing esc's and the hifei aren't bad themselves.
10-06-2011, 06:15 PM
It depends on how hard someone pushes a motor with props. A x440 and x442 isnt really pushing anything hard these days in that size range. Its really a test prop to see where you can go from there.
riggerhunter
10-09-2011, 05:30 PM
Great info guys thanks for all the help. See you on the water.
