View Full Version : 12mm threaded collet for .250 cable
FighterCat57
10-03-2011, 11:41 PM
This might be a good gas guy kinda thing. It's for a big motor I have with a 12mm threaded shaft.
tiqueman
10-03-2011, 11:55 PM
Ill dig thru my parts boxes tomorrow. I think I have a couple collets that fit a Zenoah for 1/4" shaft. Not sure what thread they are? Its been too long that I messed w/ gassers. Im forgetting the size of everything.
FighterCat57
10-04-2011, 11:31 AM
Cool, thanks!
RaceMechaniX
10-05-2011, 02:13 AM
Pretty sure that will be a non find item. The largest off the shelf collet at least made in the US is the 10mmx1mm Aeromarine collet. It has enough meat to drill out and re tap to 12mm but barely.
FighterCat57
10-05-2011, 05:58 PM
Thanks!
I'll have to see about having one machined then. Greatly appreciate the information.
RaceMechaniX
10-05-2011, 07:01 PM
Are you looking for a Square or Coller drive?
FighterCat57
10-05-2011, 07:10 PM
I'm looking to mate the 12mm threaded shaft up to a normal 1/4" flex shaft. So a set screw type collet would work OK.
It's for a big motor in a big catamaran.
carlcisneros
10-05-2011, 09:43 PM
check with Remy at aeromarine and see if they can make you one.
