View Full Version : what next
hammertime
04-25-2007, 11:47 PM
ok so i ran the quannum motor on 14 cells today.....great run by the way....it gave me a real long run time in my cat but the speed was not as much as the sv motor....... on 14 cells it was just as fast as the sv motor on 12 maybe slower..... should i a: make some 8 cell batts and run 16 cells.....B: by the sv motor and run 14......C: by the ammo motor and run 14.....D: by a fiego
hammertime
04-25-2007, 11:48 PM
ps i loved the way this motor sounded at speed....
hammertime
04-26-2007, 01:01 AM
also i have a 70a esc
saleens7
04-26-2007, 06:25 AM
those quntam motors arent as good as a feigao or any of the other motors you suggested, they dont last as long and usuallu wear out way before a feigao will...
its really supposed to be a plane motor...but you can try it for now if you want to...
04-26-2007, 08:23 AM
If you want to be faster than the stock supervee you will need a motor with similar physical size and higher kv value. You can run a 10L or 12L. Make sure with any motor change that you start with the smallest prop and work upwards.
hammertime
04-26-2007, 01:16 PM
ok.... well i have a catamaran it was almost if well into the 40s with the sv motor on 14 cells..... i wonder if i prop up and add cells if this would work...... the motor and speed control were not even hott
04-26-2007, 01:57 PM
I'm kinda lost. Which boat and motor are we talking about. I thought you were talking the sv hull and quannum motor?
hammertime
04-26-2007, 02:56 PM
no i have a bk bandit s catamaran i first took the sv motor and esc out of mt sv and put it in the cat..... than i put the other esc and quannum motor in the cat..... im goin to advance the timing on the motor a little and see what results i get..... it was fast but the sv motor was faster.... i also got a really long run time so i might prop up..... im running a x440 3 blade..... would a bigger 2 blade be better??
04-26-2007, 02:59 PM
Thats because the quanum is a much lower kv. Play with the formula on the bottom of this page to get some ideas.
hammertime
04-26-2007, 03:05 PM
what formula
04-26-2007, 03:14 PM
Sorry I forgot the link!
http://www.offshoreelectrics.com/conversion.htm
hammertime
04-26-2007, 03:19 PM
wow im not sure how to do this...ill figure it out though thank you very much
04-26-2007, 03:48 PM
Take another look at the formulas. It was changed in the conversion. It should be easier to understand now. Just change "yellow" fields to the numbers that you know.
