View Full Version : Stuffing Tube Gease NOT to Use?
sanyijr
09-23-2011, 01:03 PM
So I have seen post after post on the different greases and grease/oil mixtures out there that work. What should you (I) stay away from as far as flex drive lubes. (besides KY :nono: or beacon grease :biggrin:)
I know some bearing greases will infuse water and actually sortof foam and cuase lots of friction. And I suppose some greases are too tacky or possibly expand under heat? And definite no no's here?
-Sean
m4a1usr
09-23-2011, 01:22 PM
I would stay away from Silicone based Greases. They are not typicaly high pressure greases (thats what you want to use) and can become gummy over time. I'm sure others know of similar products.
John
I use the Pro Boat Marine Grease with no problems so far.
madmorgan
09-23-2011, 09:17 PM
stay away from gun oil
09-24-2011, 06:22 AM
Don't use general products like 3-in-One or WD-40. Thin oils are usually not a good idea. Marine greases, 70W+ gear oil, and commercial R/C cable grease are the best bets.
DBQuick
09-24-2011, 08:53 AM
Hey Fluid what do you think of Quick Silver 2-4-c Marine lubricant with Teflon that's what i am using ????
09-24-2011, 11:11 AM
Commercial marine lubes should work fine. They may or may not be the "best" but they work very well.
T.S.Davis
09-24-2011, 12:22 PM
Me too. That's my favorite to date.
ManuelW
09-24-2011, 06:47 PM
Same for me, using the Quicksilver 2-4-C in all my boats up to the HPR 135 SAW project for several years now. Can especially recommend it for use in the HPR arneson drives and the ball-beared prop shafts.
best regards,
Manuel
DBQuick
09-24-2011, 07:30 PM
Thanks guys I wasn't sure but now i am thanks again
Cooper
09-24-2011, 10:23 PM
Auto parts store, brake caliper grease, high temp corosion resistant , doesn't foam , tackey yet viscosity thin enough at temp for wire drives and flex cables, stuff works good
