View Full Version : titan 29 prop ?
murphy3428
09-23-2011, 10:56 AM
What I am running at the moment is the x445 on fdm trans with 9xl on 2x5s temps are all low my top speed has been at 43 to 44 mph but with the 2x 5s take off has been lagging most likely due to the weight. I was thinking of trying an m645 which is the same dia as the x445 but has a higher pitch has anyone tried the m645 with any luck?
09-23-2011, 11:28 AM
Without telling us the gear ratio we can't help you. I assume you are running 5S2P.
murphy3428
09-23-2011, 11:31 AM
1/6 yes 2 x 5s
09-23-2011, 11:58 AM
What is the gear ratio of the Fine transmission? 1:6 cannot be correct. Are you running the two 5S packs in parallel or series?
murphy3428
09-23-2011, 12:12 PM
Sorry 1.46 to 1
murphy3428
09-23-2011, 12:18 PM
Parallel
09-23-2011, 01:36 PM
You should be able to run an x648 with ease. That should increase the speed to around 50 mph and the takeoff should be much better. Don't bother with an x645, too small for that gear ratio.
murphy3428
09-23-2011, 02:00 PM
I have tried the ss230 with some bad results though the pitch on the 230 is double that of the 648
09-23-2011, 03:34 PM
I have no idea where you heard that BS, but the pitch on both is virtually the same - 3.0" vs 3.04". What do you mean by "some bad results"? Based on the information you have (finally) supplied it should work very well.
murphy3428
09-23-2011, 04:13 PM
Well top speed was actually less and started to thermal after about 3 minutes of run time with the ss230 temps on motor 121 not so bad but the esc 157 I thought the x648 was 1.6 pitch. I may have to just try an x447 I think the real power issue has to do with the hacker 77 not enough power for the 48mm prop
