View Full Version : spektrum rm200?
stadiumyamaha
09-22-2011, 10:24 PM
ive used the mr3000 in several boats but have never used the mr200. Do they work as well? They are a lot less expensive and i don't need the third channel
Diesel6401
09-22-2011, 10:56 PM
I use them all the time. I have more of them then the mr3000 (cost reasons like you mentioned), they work just the same.. AWESOME!
stadiumyamaha
09-22-2011, 11:11 PM
Sweet! What I wanted to hear from some one I trust. Thanks
Darin Jordan
09-23-2011, 10:26 AM
I use the MR200's all the time... both ESCs are equally fantastic!
Diesel6401
09-23-2011, 07:13 PM
:thumbup1:
Darin you hitting the bottle or something!?! :laugh:
stadiumyamaha
09-23-2011, 10:26 PM
what's a good reasonable radio that I can run several models on?
stadiumyamaha
09-23-2011, 10:42 PM
what's a reasonable radio that will run several of the spektrum Mr receivers and easy to program? What are you using diesel?
Diesel6401
09-24-2011, 01:18 AM
I use a dx3s http://www.horizonhobby.com/Products/Default.aspx?ProdID=SPMR3140. I LOVE that radio. The new dx3c looks bada$$ though http://www.horizonhobby.com/Products/Default.aspx?ProdID=SPM3300
G1ST
09-24-2011, 01:34 AM
+1 I love my DX3S.
I do wish receivers were cheaper though.
stadiumyamaha
09-24-2011, 09:14 AM
That's the two I was looking at. I think the c is all I need and for the money a good deal. Thanks guys.
Diesel6401
09-24-2011, 01:08 PM
Has double the model memory of a dx3s. I think its a nice radio. If it was out before the i got my dx3s i would have def considered it.
martin
09-24-2011, 02:40 PM
Diesel on the Spektrum radios do you bind any amount of rx to the 1 tx even if the tx dosnt have a memory facility or does the memory recognise each rx. As ive been told by some model stores that if the tx dosnt have a memory facility you should bind each rx each time you use a different model. Martin.
Diesel6401
09-24-2011, 02:52 PM
Depends on the radio. Example the stock 2.4 radio that comes with the miss geico can not handle multiple binds so you have to re-bind each rx prior to use, but the tactic 2.4s you can bind any number of rx's without having to re-bind prior to each run. Both are 2.4 and do not have model memory but they work differently. On my dx3s I have no clue, I do know that the rx is bound to a specfic channel meaning if I first bind to model memory 1 if I want to use that same rx in a different setup and a different model memory say number 2 I have to rebind it to memory 2. You can have a bunch of rx bound to 1 model memory, but you need to rebind each time I think each model memory only recognizes 1 rx per memory. Hopefully that makes some sense and answers your question.
Sent from my T-Mobile G2 using Tapatalk
martin
09-24-2011, 03:55 PM
Yes that makes sense,Its just that in the UK we have some cheapish Chinese radios as does everywhere else that have no memory but a lot bind multiple rx to 1 tx & they all seem to work ok without rebinding when they change to a diff model,Ive done this myself but have been told by a number of sources you shoulnt do it this way. Having had a boat lose steering & hit the bank & 50-60mph im now getting a radio with memory which will be a Spectrum. Martin.
Diesel6401
09-24-2011, 06:00 PM
I think you will be very please with the Spektrum products I have 3 of there radios and that's all i use. I have a Dx3s, dx5e and a dx6i and would like a dx7s or dx8 but im broke as a joke lol...
martin
09-24-2011, 06:45 PM
I prefer stick tx so was looking at the DX5e Or DX6i, Is the DX6i the better choice because of the memory.
Diesel6401
09-24-2011, 07:01 PM
Not only memory but its fully digital and provides a lot of programming features which the dx5 doesn't provide any. The dx6I is night and day compared to a dx5e. IMHO the dx6I is the best bang for your buck when it comes to stick radios!
Darin Jordan
09-25-2011, 12:36 AM
Diesel said it... You'll be happier with the DX6I. You'll have the added benefit with a stick radio of being able to run the Castle ICE controllers without needing a Pistix or to do odd things with the trims to get them to run....
