i saw this on another forum and i though it might be useful information....EDIT::
title should read, "eliminating prop TOURQUE, not prop walk...dont want to make this thread misleading)
heres a link to the thread for more info
For the right length rudder the torque from the prop on the hull can be brought to zero. The rudder length under the prop shaft level needed to accomplish this is approximately the same as the propeller diameter plus a little more.
For a boat that runs with half the propeller over the surface and the “rudder water line” level with the prop shaft the prop torque is eliminated if wet rudder is the same as prop dia. For boats with wetter prop and/or rudder water line above the prop level a little more length is needed.
The reason this is possible is that a surface-piercing prop exerts a lateral force as well as a torque. The lateral force is countered by the rudder (or there is prop walk), The rudders counter force is acting below the prop and is thus exerting a counter torque. If these torques are equal there will be no list from prop torque.
Calculations are approximate and some details are unspoken.
