View Full Version : New to the Pro Boat Stiletto..
ibo24
09-18-2011, 12:38 PM
Hi,Iam awaiting the delivery of my Stilleto,after reading some of the threads on here I think its not a case of out of the box and into the warter,
so just a few questions
Whats the best size lipos ?
Do I need to grease the Flexishaft if so what type of grease ?
Is all the electrics waterproof ?
Any advice would be most wellcome,
Thanks..
PS cant you tell Iam new to RC boats and allso new to this forum..:smile:
Diesel6401
09-18-2011, 02:04 PM
Thanks..
Welcome...
No boat or rtr rc anything is really out of the box and play with it. When it comes to mass produced rc's you have to go over them with a fine tooth comb. Yes you should lube the shaft prior to operation and also check all the hardware and make sure everything is secure. Grim racer speed grease is the best (in my mind). Yes the electronics are well sealed. Lipos can be 2x 5000mah 30c+ or 1 4s 5000mah 30c +. A good place to start is also changing out the deans connections and changing out the motor/esc bullets to 5.5mm or higher. Also check the proboat section of this forum for future questions.
ibo24
09-18-2011, 02:49 PM
Thanks a lot all advice taken onboard,and yes I found the Stilleto thread..
