View Full Version : 1500 vs 1800 motor
roadrashracing
09-16-2011, 08:52 PM
what one will give you more speed? I know the 1500 has more torque but what will that do for a boat?
JimClark
09-16-2011, 09:13 PM
1500 will Handel bigger props
roadrashracing
09-16-2011, 09:16 PM
I guess the best is just trial and error?
09-16-2011, 09:37 PM
The 1800 will give better speed on this boat. A large prop upsets many monos, promoting chine walk and handling problems. The 1800 will still spin a smaller but adequate sized prop faster. The 1500 will draw less amps if propped appropriately and extend run time.
roadrashracing
09-16-2011, 09:44 PM
I have a grim 40x53 would it work better with the 1500 I get less performance out of the 1800 vs stock.
09-16-2011, 10:23 PM
You'll be slower with that small, low pitch prop on a 1500 Kv motor. I believe that is smaller than the stock Impulse prop.
I don't understand the last part of your sentence. The Impulse comes with an 1800 Kv motor as the stock motor.....
TheShaughnessy
09-16-2011, 10:27 PM
that prop with the 1500 kv on 6s, now you're talking some speed. Don't know about a 60 amp speedo though.
martin
09-17-2011, 05:09 AM
As Fluid has said that 40 x 53 is to small only 2.08" pitch, The stock prop is 2.51" pitch. Martin.
roadrashracing
09-17-2011, 11:03 AM
so that prop I should just get rid of?
