View Full Version : Motley Crew Leopard 4074 install
Pete32200
09-13-2011, 10:06 PM
The UPS man dropped off my Motley crew this morning that I bought here in the For sale section, I proceeded to gut it and install carbon fiber in the hull and hatch, a new motor mount, a B/S X445 prop and an 1800kv leopard 4074 motor ( the seaking 180 and upgraded flex shaft were already installed )
http://i188.photobucket.com/albums/z245/1973v8bug/MotleyCrew009.jpg
http://i188.photobucket.com/albums/z245/1973v8bug/MotleyCrew006.jpg
http://i188.photobucket.com/albums/z245/1973v8bug/MotleyCrew008.jpg
http://i188.photobucket.com/albums/z245/1973v8bug/MotleyCrew010.jpg
99z286spd
09-13-2011, 11:04 PM
Nice job man! Glad you are going to get some use from it ! Just a note... I tried that deans connector thing.... They will get hot....mine melted a solder joint, but once I went back to 5.5 on the batts it was all good.
And with that 1800 kv setup the only thing that probly will get warm will be the batteries!
Good luck!
Leon
Pete32200
09-14-2011, 09:29 AM
Stopped at the lake on my way to work this morning, it was running a little wet but handled great and it seemed like low to mid 40's speed wise, I think I can get a little more speed by adjusting the strut and CG, right now the strut is adjusted so it sits flat and level on the set-up board.
The motor, all the connectors and esc were all under 100 degrees after 4 minutes of running and the lipos were 105 degrees.
Make-a-Wake
09-14-2011, 09:54 AM
You can turn a prop with more total pitch using that 1800kv Leopard...................an Octura x642 would get you a good speed boost, dont know if the hull wants alot of diameter but you could also try an x447.......
Pete32200
09-14-2011, 09:59 AM
I may have to try one of the x642's....I have a 42x55 and x440/3 I still want to try
09-14-2011, 10:17 AM
I got near 50 mph with an m445 and the stock 1800 Kv PB motor in mine. You should be able to spin an m545 or m645 with that motor depending on temperatures and the speed you want. You need more pitch than an x440 has to go fast.
Diesel6401
09-14-2011, 12:33 PM
Yea that motor can swing a nice prop. I am running a x447 on my 1800kv leopard and it runs good. I run it on 4s1p, but like fluid mentioned a m645 would be better. I run a m645 on my Leopard 4074 2200kv in a Pursuit mono on 4s2p. Runtime suffers but shes a batt outta hell. I would even say maybe a s225 might work. DOn't trust those deans they ARE the week link you setup right now. Get rid of them asap!
Pete32200
09-14-2011, 01:39 PM
I have 10 pairs of 5.5 bullets.....I guess I will go home and start soldering
bruce5385
09-14-2011, 03:48 PM
i suggest that you stiffen hull up or add the 2 part foam to inside if you plan to go over 50mph. my boat is coming apart from bad crashes over 50mph. seems like the hull flexes and cracks/splits. i believe if you fill with foam like the ul-1 guys are doing it will be ok. im in process of trying to get new hull now and fill it with foam. good job on your build. good luck
Pete32200
09-14-2011, 05:42 PM
When I was up at Kintec racing picking up the CF and motor mount Jan was telling me I need to foam it also, I am just afraid I will add too much and split the hull
bruce5385
09-14-2011, 06:16 PM
http://forums.offshoreelectrics.com/showthread.php?6308-make-your-UL-1-rock-solid is a link to article on 2 part foam. if u use the 2 part foam it is light and will not break boat. if u use the foam from home improvement stores you will have a problem.
siberianhusky
LOL I should use mine as a plug, make a mould and build myself a carbon fiber hull, see what the design is really capable of, I bet it's impressive if you're not afraid it'll blow apart!
Wonder if you could cut the deck off, add some carbon fiber to both the deck and hull and glue them back together?
bruce5385
09-14-2011, 06:47 PM
i think poping the two pieces apart can be done. looking at mine were it is coming apart it seems to be like a shoe box(bottom and lid) i called aquacraft and you cant buy a new hull so im gonna have to add the foam or split the two halfs and add some material. at 60+ mph the crashes ive had are not good. next one will prob blow the boat apart. almost broke off right front part of boat(were it comes to piont about 2 in back cracked 80%around) split hull at seams(2 inches from back all the way around, in front in between the fork) also crushed in lid, stress cracks bottom center of hull in tunnel, and on right sponson on bottom(bad enough to take gelcoat off) i believe you can reach 70+ mph with no problems if you foam the inside.
JPriami
09-14-2011, 07:03 PM
Just don't crash and it will be ok. Lol. Just kidding
bruce5385
09-14-2011, 07:13 PM
yeah i wish it was that easy lol!:thumbup:
Diesel6401
09-14-2011, 07:23 PM
I have filled hulls before with the home improvement foam. Worked fine for me. You just have to have places for the excess foam to escape. If it expands to much with no place for the excess to go it will split the hull. Good move on the 5.5 for the batteries. I am also using 6.0mm bullets from Hobbyking. They are truly awesome connectors, way better then the HK 5.5 bullets and more on par with cc 6.5s.
Pete32200
09-14-2011, 08:35 PM
Kintec sells small quantities of the 2 part marine foam, I will have to pick some up next time I am there.....Maybe I will go ahead and foam the UL-1 also
JPriami
09-14-2011, 08:40 PM
Use a little at a time. Too much and it will expand then the outer layer will dry and harden. Leaving some trapped inside that's not cured. Then when it heats up it will expand and pop goes the hull. I am speaking from experience. But I managed to save it because I caught it before it busted. I poked holes in the foam letting what was trapped and expanding to have a way out. Now it's all fully cured and has added more strength to the hull of my MG.
Btw if anyone gets the spray stuff get the blue can.
bruce5385
09-14-2011, 08:59 PM
same happened to me. old supervee had nice buldge in nose. lol but the home improvement stuff will hold water(if u cut the dried foam it leaves it were water will absorb in foam) that was with the red and yellow greatstuff though.
Pete32200
09-14-2011, 09:14 PM
Now I am afraid to try it !!
Pete32200
09-16-2011, 09:01 AM
What is a good timing setting for the 1800kv 4074 leopard?
JPriami
09-16-2011, 09:56 AM
I emailed leopard hobby about those motors to find out if they are a D or a Y wind motors. They said it's a D wind
D winds are normally 0-5 low 5-10 med deg of timing
Y winds are 0-10 low and 10-15 med deg of timing.
Diesel6401
09-16-2011, 02:00 PM
WOW now that's interesting. My Leopard 4074 1774kv ( i guess this 1800kv replaced it) was actually a wye wind and likes 15* timing. Interesting on that and good info. I guess to be safe run at 7.5 on the timing. Kinda that happy medium between both winds. I ran a Tacon (leopard clone) delta wind at 7.5 and it ran very VERY well at that setting.
09-16-2011, 04:33 PM
I emailed leopard hobby about those motors to find out if they are a D or a Y wind motors. They said it's a D wind.All the other 4074s are apparently Y winds, see here: http://www.leopardhobby.com/product/product_veiws.asp?id=1251&functionID=01020201
The Y motors like timing, the amount depends on the load. I would not run more than 5* advance on a D wind as it just generates excess heat, not power (except in outrunners, but that's another subject).
Diesel6401
09-16-2011, 04:47 PM
I use to have a much more detailed print out of Leopards chart. They started changing a lot and removing a lot of data so I printed it a while ago, it had both y and d winds information on it. Now the real issue is finding what i did with the print out :confused2:
Pete32200
09-16-2011, 07:29 PM
I went to an M645 prop and 5.5 bullets on the batts ( and picked up another pair of 2s 5000mah 40c turnigys while I was at Kintec Racing today....I love having a full service R/C boat shop near by :biggrin:... Set the esc timing to 3.5 degrees and headed to the lake, My Nuvi 200 GPS said 49mph and it seemed a little faster without the weight of the huge GPS crammed in there, So I am assuming I am at right at 50mph. The motor and esc temps were less than 120 degrees, however the 5.5 bullets on the motor got to 165 and were smoking.....and the 5.5 bullets on the batts were at 135.....when I run with the deans on the batts the deans connectors are only at 125 degrees. would some di-electric grease help or hurt the connection?
I also picked up some 2 part foam to do the MC and my UL-1, I should have some pics up of that process this weekend
Pete32200
09-17-2011, 04:23 PM
6036160362603636036460365
Got the foam in the hull last night, I originally was just going to drill a couple 3/4" holes to pour through but found a piece of foam in the nose ( and it was holding alot of water ) so I cut a slot large enough to slide it out, it wasn't glued in or attached at all, it just pulls out
After removing the stock piece of foam I could see plywood sheets running flat inside the sponsons front to back, they have large holes in them so the foam will pour right throught them without issue
I started by mixing 1oz of part A and 1oz of part B ( 2 oz total ) and did my first pour, Waited 30 minutes and Repeated that process 2 more times for a total of 6oz ( 3oz part A and 3oz Part B ) that got me very close so for the final pour I mixed 1/2oz of each and that filled it......I thought :cursing:
Apparently there is a piece of plywood or some other material that runs across the nose and prevented the foam from filling up the front 2 inches of the hull......THE MOST IMPORTANT PART !!!!
so If you are going to fill the hull get in there with a long drill bit and put some holes in there for the foam to pour through, I need to figure out the best way now to get foam in the nose :frusty:
JPriami
09-17-2011, 06:42 PM
Nice job
JPriami
09-21-2011, 08:10 PM
On the connectors getting hot try spreading the prongs out to make sure they fit snug. Maybe even go over them with fine steel wool to make sure they don't have anything stuck to them. I imagine the dielectric grease idea wouldn't hurt.
Checking the soldering connections by re-soldering if that don't help.
detox
09-21-2011, 08:25 PM
This hull is begging for more kv. The Neu 1515 1y (2200kv) or Castle's 1515 1y. Of course maybe a leopard 2200kv motor.
Pete32200
09-22-2011, 04:42 PM
It did melt the solder off one of the motor connectors the other day, I replaced the 5.5's that were on it with some HK 5.5's ( suprisingly they fit together nice and snug ) so I will see what happens next time out
Diesel6401
09-22-2011, 05:00 PM
I'm using the HK 6.0mm bullets on my 4074 1774kv motor, they are AWESOME connectors! I get my 5.5mm from a seller on ebay and I love them. On my Leopard 4074 2200kv I am using CC6.5mm bullets.
Pete32200
02-02-2012, 07:07 PM
This nice weather has got me wanting to run the boats again so I headed up to Kintec Racing today and picked up a Leopard 2150kv 4074 to try, I also swapped out to a UL-1 Rudder with the built in water pickup. I am gonna try and hit the Lake tomorrow :thumbup:
Make-a-Wake
02-02-2012, 08:26 PM
You got 'soft' water in PA?
slapahondn
02-03-2012, 12:54 AM
I am running the same set up with a tacon 2150 and a x447 and it runs great.
Pete32200
02-03-2012, 07:07 AM
Looks like its gonna stay "soft" for another couple weeks :thumbup1:
Make-a-Wake
02-03-2012, 10:17 AM
Great for you!! I like running in 40* water.............cools everything down real nice!
slapahondn
02-04-2012, 02:10 PM
Pete i think you are allright i just did the same thing to my mc and didnt see anything that would block the foam from going to the foreward most part.
Pete32200
02-05-2012, 08:01 PM
Thats odd, the front of the sponsons and front edge of the main hull on mine feel like no foam got down there, I can still flex those areas
petej
03-04-2012, 01:04 PM
How'd the 2150kv Leopard 4074 compare to the Leopard 1800 in your MC?
slapahondn
03-05-2012, 09:49 PM
I got the boat without a motor so I have only ran it with the 2150kv.
floatn turd
03-06-2012, 12:41 AM
I ran a 2150kv then switched to a 1160kv so I can run bigger batts, I posted what I thought, in this fourm " **New** AquaCraft Motley Crew Brushless Q & A" under "Tested my new set-up today, and gotz me a questionz"
If you want read the whole thing. or see a pic of the inside of my boat.
But here is what i said:
Tested my new set-up today, and gotz me a question.
Testing info:
Purchased a Motley Crew, ran it "stock" once. (to slow)
Bought a Leopard 4074 2150kv and Swordfish 200amp. Ran once on 4s, then learned that 4s was the max I can do with that motor. Well that does my 3s and 4s packs no good.
So I sold and replaced the all that with a TP 4050 1160kv and 8s- 240 ESC from Fightercat.
Now for today:
I started with 6s on a m445, ran perfect, and cold.
*Note* The TP on 6s "seemed" to be the same as the Leopard on 4s, on top-end speed, but the TP had a ton more mid-range punch than the Leo.
**Note 2** The Leo sounded better than the TP
So I skipped the 7s and went straight to the 8s. HOLY CRAP!!! that thing was fast... gave the throttle a squeeze and it jumped out of the water about a foot. It busted off the nylon sheer bolts on the rudder and flipped over. Fixed it and tried again. I could only give it full throttle for a second once it was "under way", cause it would hop right out of the water. If it had wings it would fly away, and I didn't want to wreck the hull on the first time out. I don't own a GPS or a camera person, but it hauled A**!! only at prob. 75% throttle most the time. When I did go "full" for a second= She flew like a "raped ape"
Right up until I snapped my flex line.
Pete32200
03-14-2012, 06:11 PM
the 2150 leopard was a definate improvement, with the m645 prop on 4s it is much faster, haven't GPS'd it but compared to the 50mph it was running I am gonna estimate 58-60 mph now. It was getting a little warm so I may have to prop down once the water gets warmer but overall I am pleased with the set-up
Pete32200
07-09-2012, 09:23 PM
Have settled on an M440 Prop since we started doing some "Racing" Down at The Kintec Racing proving grounds, Not quite as fast but temps stay down around 110 degrees F on the Motor and ESC and handles like a dream
petej
07-10-2012, 01:29 AM
Working on the MC is a breeze. I installed the Leopard 4074, 2150kv motor on a carbon-fiber motor mount, been running my MC with the Seaking 180A ESC, x642 prop, a pair of 4S (parallel) 40C 5000mAh Sky Lipo batteries. The acceleration is amazing and she easily hits 50mph with cool component temps.
Comparing my modified MC to my modified EKOS C1 2(Leopard 2860 2730kv):
- Turns: MC tighter, faster.
- Rough water: EKOS "ploughs" through, where the MC is more prone to submarine. The EKOS with 2(motors, ESC) is heavier, narrower beam, slightly longer hull and lower profile.
- Speed: EKOS very stable at or above 50-60mph. MC can only handle short bursts, then can get wobbily and more easily kites to the air.
- Reliability: MC, hands-down.
- Ease to work on: MC.
xlandguy
07-24-2012, 06:24 PM
I have finaly "finished" my MC upgrades, for now. Carbon fiber inside the hull, a little on the hatch. New motor mount and wiring, Aquastar 120 amp, 5.5 bullets battery side, 6mm for motor connection. Traxxas waterproof servo (125oz). Foamed hull with two part marine foam from Kintec. Grim 42-55, Kintec flex, slightly shortened stuffing tube, oversize cooling lines. Waterproof rx box, and more! Love working on these boats, this one, and my 30 yr old Villain.
tlandauer
07-25-2012, 12:58 PM
xlandguy,
that is really great, post some video if you can. I have a question: I plan to foam my hull since there is something already "loose" in the nose---can hear a rattle sound , boat is brand new. How many minutes do you have when you start mixing that stuff till it starts to expand? I am a bit slow and worry that I don't have enugh time, lol...
xlandguy
07-26-2012, 03:01 AM
Not "minutes" more like A minute, you mix in small (1 or 2 oz) batches. There is a piece of foam in there, I pulled that out first, take a look at my other thread to see pictures and video. The foam from Kintec has decent instructions. Not difficult, just plan, mix and pour.
tlandauer
07-26-2012, 03:26 PM
Thanks! So it's ONE minute, just as I was afraid of...:scared::rofl:
xlandguy
07-27-2012, 12:18 AM
Ya if I recall you mix for like 20 seconds or so then pour it in. It's very thin when you pour, a minute is plenty of time, but don't e wait.. Pour it as soon as you mix it. Get the little mixing cups from Kintec and it's easy to get it right. Take a look at the other threads on this foam. Lot of guys did it to their UL-1's.
tlandauer
07-31-2012, 04:54 AM
Thanks for the tip, that is important for me to know! I think i will give it a practice run on something else.:tiphat:
