View Full Version : What Feigao Motor in this Hull?
tanzi411
09-10-2011, 06:25 PM
I have a ABC Hobby Fighter 550 crackerbox hull. Its ABS but i am going to lay down wood and carbon fiber.
What size and turn feigao motor should i use and what lipo batts?
Thanks!
09-10-2011, 06:56 PM
That hull is speed-limited - too much motor and it isn't even drivable. We ran them with 19T 05 brushed motors and x432 props on 6 NiMH cells. Today a Feigao 12S on two LiPo cells - 25C/3300 minimum - with an x427 or x430 prop should work well - the plastic x431 may be great too. If that's too slow for you, go up to an x435.
tanzi411
09-11-2011, 04:46 PM
ok so many i will just do a 19T brushed motor.
What motors do you recommend? 7 cells?
09-11-2011, 05:19 PM
I have not used an 05 brushed motor for years, I don't know much about the current offerings. I'd choose from among these:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXATKB&P=0
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHUJ1&P=0
http://www.advantagehobby.com/56463/EPXEP1122/?cat=354
Use SIX NiMH cells.
tanzi411
09-11-2011, 07:17 PM
whats the difference between single and double turn motors?
Chenige
09-12-2011, 07:08 AM
I am a FE newbie here but I had the same questions a few months ago. Per the info here I replaced the 19T brushed motor with a modern brushless in a 20" mono. It is a 3650 so the same physical size as the 19T ones listed above.
The way I have it set up may be a bit too fast though so you may want to go with a different kv/battery cell combo. My too hot combo gives me 33,000 rpm because I thought I had a 15T in the boat which would have given it 27,000 RPM instead of the actual 19T 22,000 rpm. So I increased the Kv more than I should have.
Perhaps someone else can chime in on the right rpm for your boat. ESC and motor and battery are staying cool for me. Do a search on Electrified if you want to see more about my boat. Still tuning it in. Having issue with prop walk (makes a right turn).
2950 kv motor with 3S. Got it on sale for $22 three weeks ago though: http://www.hobbypartz.com/96m26-car-3650-2950.html
You should go with either a lower kv motor (I see a 2230) or go with 2S with a higher Kv version?
09-12-2011, 07:26 AM
Perhaps someone else can chime in on the right rpm for your boat....
"They" already did, post # 2... :olleyes:
Today a Feigao 12S on two LiPo cells - 25C/3300 minimum - with an x427 or x430 prop should work well...
Chenige
09-12-2011, 11:17 AM
What is the Kv of a fiegao 12S? OK I looked it up. 2958.
So on 2S around 22,000 RPM
