View Full Version : Best place for water pick up on a hydro
monojeff
09-06-2011, 01:44 AM
I have a small hydro I'm just about finished with.
I need to know best place to put a water pickup as my rudder doesn't have a built in one.
Not sure if a prop wash type would be suitable or putting it on the rear of one of the sponsons??
Any help appreciated!
09-06-2011, 07:22 AM
Either one works, although the prop wash is usually easier to do with simpler plumbing. Put the pick up in the 12 to 3 o'clock quadrant or the prop wash, closer to 1:00.
Jesse J
09-08-2011, 09:41 PM
Also prop wash one will have the most constant water flow. I have had them also under the sponson with equal success. I am setting mine up with propwash for the more continuous flow.
monojeff
09-08-2011, 10:09 PM
What is the best way to make one for a small hydro bend some tubing and have it come out the back of the transom over the prop as fluid mentioned?
monojeff
09-08-2011, 10:11 PM
Never mind I just googled prop wash pickups and found a suitable photo of one I can make.
Also noticed one on here
http://www.offshoreelectrics.com/info-pages/add-water-pickup.php
monojeff
09-09-2011, 12:57 AM
Will this work?
http://i10.photobucket.com/albums/a121/bizkit21/c7ced9fe.jpg
http://i10.photobucket.com/albums/a121/bizkit21/9ed78382.jpg
Or should the tapered edge be on the other side?
09-09-2011, 06:50 AM
That won't pick up much water, face the tube 180 degrees around. This would work better although I'd put it further back and on the other side of the mount:
http://i52.tinypic.com/2q9jv9i.jpg
monojeff
09-09-2011, 01:35 PM
That's what I thought I flip it and switch it to the other side.
Thanks
monojeff
09-09-2011, 01:37 PM
It's about as far back as the pic you posted??
monojeff
09-28-2011, 03:26 AM
Well my pickup didn't work to well motor came back way hotter then I would have liked, I could barely touch it.
I guess I need to move the pickup back more how much further would you suggest??
Gotta keep temps down I am running a 4000kv motor on 3s in this little hydro.
It ran great just don't want to smoke anything!!
sundog
09-28-2011, 12:53 PM
That pickup won't do - it is made to go on the transom of a submerged drive boat. The slanted part faces the front of the boat, but the pickup is molded such that you can't turn it without turning the whole thing.
monojeff
09-28-2011, 01:17 PM
I can always cut it so that the taper is on the back rather then the side.
So move it back a little then adjust the taper and you think I'll be good?
sundog
09-28-2011, 03:23 PM
You want the taper to be on the front - facing the front of the boat. And it has to be in the prop wash when it's running - it won't do any good if it's too high to catch water. And it will do even better if you tilt the bottom toward the front (just a little) too.
monojeff
09-28-2011, 11:25 PM
Yeah sorry I meant taper in front I said it incorrectly.
I will try to adjust this and see if it works better next time out.
Thanks
properchopper
10-05-2011, 11:05 AM
Jeff,
Made this yesterday for a project boat. Top will be trimmed shorter.
61638 61639 61640
monojeff
10-05-2011, 09:53 PM
Nice I will be adjusting mine soon hopefully will work better next time out.
properchopper
10-09-2011, 01:57 PM
Jeff,
Here's the completed pickup. I wanted two: rudder + propwash to provide extra cooling ; one for SC & one for motor for this application. ( prop's mocked up for clearance measurements)
61885 61886 61887
