View Full Version : Rudder slop
Mtwinste
09-02-2011, 06:37 PM
Do your impulse have about 2mm of left right play in the rudder independent of servo rod movement? It's in the rudder assembly itself.
When I'm at WOT which is about 50 the boat starts walking on me and I'm thinking this rudder play cannot be helping.
svtfrank
09-03-2011, 05:30 PM
YEAH!!!!...................HOW DO WE FIX THAT???? Mine does the same thing!
Mtwinste
09-03-2011, 08:17 PM
Idk
lenny
09-03-2011, 09:35 PM
Try the set screws on the rudder arm.
Steve@TheHardRichards
09-13-2011, 04:53 PM
I removed the rudder,lossend the set screw on top, spun the shaft so the set screw actually set in the cut out on the shaft, the reinstalled everything and ive ran 5-6 times now with no slop.
see if that works for you.
remember metal to metal so you may need to dab some threadlock on the set screw b4 reinstall.
Mtwinste
09-20-2011, 01:30 PM
I made sure of that and still slops. If anybody does the fix above and still slops let me know. Something is up.
Darin Jordan
09-20-2011, 01:35 PM
Something must be up, because if everything is tightened down properly, it shouldn't have any slop at all. You never quite know who they have over there in China assembling this stuff, so it's always a good idea to double-check everything.
texas347
09-20-2011, 10:50 PM
They aren't putting the set screw in on the flat spot of the rudder shaft - I had the same problem. The top screw was fine but the lower one as not seated correctly. Easy fix.
