View Full Version : Throttle is on if radio turns off
Mtwinste
08-29-2011, 09:13 PM
If I turn off my radio the throttle instantly goes about 30%. How to fix?
JimClark
08-29-2011, 09:14 PM
turn your radio off last when you are done
Mtwinste
08-29-2011, 09:23 PM
What if I run outside of range or controller batteries get weak. The same thing will happen and runaway boat.
carlcisneros
08-29-2011, 09:48 PM
If your radio is set up with failsafe, (we do not know what radio you are using), please us that feature and set the failsafe to go to
OFF throttle if the range goes too far or the transmitter is turned off first.
you should always turn off the transmitter LAST.
Mtwinste
08-29-2011, 09:52 PM
Spektrum DX3S and MR2000 receiver.
Mtwinste
08-29-2011, 10:09 PM
I don't see a fail safe mode on DX3S
carlcisneros
08-29-2011, 10:12 PM
I am sure that someone with the spektrum radios will chime in.
I use NOMADIO and Flysky GT3B radios.
both have fail safe features.
JimClark
08-29-2011, 10:14 PM
read page 17 of your manual
Shooter
08-29-2011, 10:16 PM
What ESC are you using
Mtwinste
08-29-2011, 10:40 PM
Page 17 of instructions sorry duh
Darin Jordan
08-30-2011, 10:35 AM
You need to rebind the RX to the TX... The failsafes are set when you bind. Sounds like you may have had throttle trim or throttle on when you bound it??
BBQSteve
08-30-2011, 11:05 AM
Mine does something similar with radio on. Throttle goes to 25% and no radio when battery is supposedly low, however when I retrieve it, turn radio switch off then on it regains radio and motor quits running. This has to be in the ESC (ProBoat waterproof ESC with reverse PRB2314).
BBQ Steve
