Help?,...Basic stuff for some....BUT....
  • lonneyb
    • Feb 2011
    • 83
    Maybe you all could answer a few questions before i go messing with stuff...
    What do the Turn Fins Control and how should they be installed ...SHarp Tip pointing out? ...tip down?...kinda in the middle?...I guess knowing WHAT they help with, would let me understand how to adjust them...
    What happens when i put the Rudder Deeper and Vise versa raise it?...ie: the effect it has on
    the boat..
    and lastly...the trim tabs...what happens when they are tilted more towards the water
    and again or vise versa more up towards the back of the boat
    Thanx for helping a newbie understand the controls
    Spektrum Radios
    Proboat "Impulse" 31 Deep-V
    Proboat "Mystic" (On the list!)
  • lonneyb
    • Feb 2011
    • 83
    no one?
    Spektrum Radios
    • ejimbo4
      • Jul 2011
      • 189
      I am new to rc boats myself and just got a Impulse31 and I have had some of the same questions but with some searching and reading I came across this.....
      Hope it helps!
      Everything I do I learn something new!
      • roadrashracing
        • 1462
        sorry I just put them in the water and move batteries if I need to.
        • Mtwinste
          • Jul 2011
          • 135
          The best thing to do is adjust try adjust try adjust try. Go from one extreme to the other on each adjustment. We learn by extremes then we use knowledge to find the tune.
          • stadiumyamaha
            • 1284
            the turn fins help the boat turn quickly without spinning out. The sharp side to the outside pointing down far enough to let it turn without slowing in down. They are angled out while the boat is level but in a turn they are straight vertical. Hope it helps.
            white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
              • 8012
              The provide side resistance when the boat turns, reducing the tendency to spin out. Start with them as deep as they will go, then slowly raise until the boat hooks.
              the boat..
              You can't raise or lower the rudder vertically, I'm confused here. Angling the rudder does little the way the Impulse is set up. Keep it vertical to the water.
              Tilting them down pushes the bow down, and vice versa. If they are too far down they can hurt turning since they push the transom up.
