View Full Version : SAW Motor KV
LarrysDrifter
08-24-2011, 11:48 PM
Ill be beginning making my Drifter L into a twin in the near future. Its going to be set up as an un-official SAW boat. I plan on using 2200kv Leopard motors or Neu's. I realize the Neu would be the wiser choice, so Ill see whats in stock here when Im ready to order the motors. As for the Leopard, Ive been looking at the 4074 and the 4082 both in 2200kv flavor. I know the 4082 will make more power, but I believe, if memory serves me correctly, they ran hot on 4s? This build will be ran on 6s. Yes, Im aware of the high rpm of this set up. This wont be my first high rpm twin build. As for the new guys here, dont run this kv on 6s and dont run it as a twin until you have some experience in FE first. I dont want to put this in anyones mind that is ok to run and be reliable.
RaceMechaniX
08-25-2011, 12:39 AM
Sounds like you have answered your own question.......
LarrysDrifter
08-25-2011, 12:58 AM
Not really. I m hoping someone with the 4082 2200kv leopard will chime in and give some info and temps on this motor. Im curious about the leopard because of the 3 Ive had, Im very impressed with them. As for blowing a motor, of course Id rather cook a Leopard instead of a $200 Neu.
bbill1
08-25-2011, 03:50 AM
I have a 4082 2200kv in my Shaman Tunnel (32 inches) on 4S and it rocks! Runs right at about 60 in heat race trim. Motor usually comes back around 100F, SF200A speedy 135F, batt 105F.
Don't have any info on 6S, but I did set an IMPBA Q Tunnel record last year at Huntsville with a Neu 1515 (2200kv) on 6S in a Lynx tunnel (29.5 inches) of 68.8 mph @ 3.287 seconds. It fell a week later to Mike L. and Dick L.
But yeah, 2200kv on 6S is a little on the hot side and is asking for... :flashfire:
08-25-2011, 07:26 AM
But yeah, 2200kv on 6S is a little on the hot side ...Sure it is, but as stated in the first post this is a SAW-only setup. As long as he does not run too long, makes only a few passes and comes in, he'll be okay. I've run what he does in singles and it works; dividing the load between two motors can only help.. The ESC is the weak link.
bbill1
08-25-2011, 07:31 AM
Which is why I did it as well when I went to Huntsville. I didn't tell him not to do it.
Jacked1
08-25-2011, 08:46 AM
I agree with the esc being a little on the small side for that. In my head the reason for running higher rpm is to be able to use the same size motor on the same voltge but the higher kv handles higher amp draw. That is going to be a TON of power!!:buttrock:
LarrysDrifter
08-25-2011, 09:35 AM
Thanks for the help, guys. Bill, thats the info I was looking for. Now, to figure the speedos Ill need.
