View Full Version : Df cyberstorm
ENCORE MAN
08-24-2011, 04:44 PM
Here is a new DELTA FORCE CYBERSTORM I had Ray Fuller build for me. I will run a Leopard 4074, 2000, m445 or m447 on 4s with an Etti 150 opto esc. Can't wait to get her wet on days when its too windy for my cats and hydros. Brian Giardelli
Rumdog
08-24-2011, 04:53 PM
Looks good. You may want to glass that motor mount in a bit and lay a little down around the mount on the floor to stiffen it up.
ENCORE MAN
08-24-2011, 06:02 PM
Thanks Rumdog.....This hull will go on a glass,epoxy diet before the Hyperions are plugged in.
yurkanip
09-08-2011, 10:38 AM
Nice looking cyberstorm...I run that hull and it rips. I would suggest if you don't mind, the 4082 1800kv vs the 2000 on 4s2p. It will turn a 447 and 450 three blade without breaking a sweat. I run a castle 1518 1800kv and a sharpened, thinned x447 three blade and it is the Perfect combo!!
Just my two $, on a great running hull. Good job.
Drax21
09-25-2011, 04:29 PM
They are great looking Hulls. I already have a HK Copy (The Pursuit) but I know the Cyberstorm is the best from all the races this Hull has won. I just bought a Red one off of Ray Fuller, once I saw the pics I had to buy it. I run a 4074 2364 Keda Motor in my Pursuit but I am definitely going to get a bigger motor in this Hull. Yurkanip your set-up sounds good. Have you got any vids of it running?
ENCORE MAN
09-25-2011, 06:16 PM
Castle has discontinued the 1518 1800 and I can't locate a Leopard 4082 1800 motor. Good luck with your new Cyberstorm. I will try a Leopard 4082 2200 on 4s and see how it goes. TTYL BG
Drax21
10-10-2011, 07:47 PM
I have seen some Leopard 4082 2000kvs on ebay. Steven said he will order them in. I am also looking at the 1518 as I believe this is the equivalent of the leopard 4082. There are still some around.
