I had my first chance to run the Stiletto today after spending the last few days reading most of the posts here. Without any info on C/G or where to set the outdrive, I settled for placing 2 5000mAh 2S one in front of the other and setting the outdrive all the way up and neutral. The only mods I made were to enlarge the hole on the motor cover, made a lexan battery box lid, replaced the imitation S215 for a real Prather S215, and replaced that large prop nut with a more appropriately sized prop nut.
I also set the ESC with the following parameters: Battery: LiPo, Cut Off: Low, Cut Off Type:Idle, Brake: Off, Timing: Low, and Throttle Curve: Linear
Anyway, The wires, connectors and batteries are getting extremely hot. I was prepared for the Deans plugs to be hot, but the wires and batteries were extremely hot also. My batteries actually have 5.5mm bullets and 8 gauge wires, but I have some 5.5 bullet to Deans adapters that I made which have served me well for other set-ups.
The ESC seems to be OK and unfortunately I don't know how hot the motor was because this dummy left the dummy motor cover in place and forgot to bring my screwdriver to the lake so I could remove it.
but the wires and connectors leading to it seemed to be cool.
All of my battery packs were Flightmax 5000mAh 2S. The first packs were only 20C and pretty well at the end of their life span, but I planned to only use them for the initial run with what little they had left in them. The second packs were 30C (actually 5800mAh) and they performed well, but the connectors got so hot they melted the factory Stiletto battery cover
The third packs were 40C and things were as hot as with the 30C packs...fortunately not hot enough to melt Lexan!
So given the above information, does anyone have any thoughts or suggestions?
Thanks in advance for any help
