View Full Version : Impulse 31 leaking..
GOGEICOGO
08-18-2011, 06:19 PM
Has anyone figured out where this boat is leaking from? It seems to only leak when running the boat in a bit of chop. It doesnt apper to be the lines or the drive shaft tube. After every run there is usually a little puddle of water at the rear of the boat on the left side.
Diegoboy
08-18-2011, 09:00 PM
Thread moved
Did you get a second one?
Darin Jordan
08-18-2011, 11:24 PM
Check the holes where the front of the hatch pin inserts into, and where the rear hatch lock slots into. The factory failed to seal these holes... This was discussed in another Impulse 31 thread here previously. Do a seach and you should find some fix suggestions...
