View Full Version : Run time with NIMH
VJSC
08-17-2011, 10:21 PM
I'm thinking about getting an Impulse 31 and just have 3300mah 7.2V Nimh batteries. I will only use the boat a few times this year then over winter save up to get lipo batteries and good charger. Without using a programing card, how long will run time be with the aforementioned Nimh batteries?
08-17-2011, 11:23 PM
Depending on how you prop it and how you drive it, around 3 minutes. Try not to run the packs down completely, that can overheat NiMH cells.
VJSC
08-17-2011, 11:29 PM
stock prop, half to full throttle in mild chop.
08-17-2011, 11:55 PM
Half throttle is hard on the ESC, avoid too much of it. I'd still say around 3 minutes, maybe up to 5. The more acceleration and slowing down you do the less the run time. Cell quality matters too....
