View Full Version : Reinforcing the hull
NorthernBoater
04-24-2007, 11:15 PM
On the Syncron should I reinforce the part of the hull the strut mounts on.
brooks93
04-25-2007, 12:07 AM
if you mean put in a transom doubler then yes if there already isn't one there. is it thin like the rest of the hull?
04-25-2007, 07:19 AM
You should glue a plywood doubler inside the transom if there in not one there now. I use 1/4" ply on a boat that size - hobby grade, not weak construction grade interior ply. Don't froget to waterproof it with a coat of thinned epoxy or similar after installation.
NorthernBoater
04-25-2007, 11:05 PM
Yes the transom is thin like the rest of the boat. What do you thin the epoxy with?
