midnightsabotage
08-12-2011, 06:39 AM
Hello, I'm hoping to pick up a Castle 1717 1580kv motor If I can get the money before they're out of stock again... but before I do, I want to be sure I'll be able to use it in something.
Boat-wise, what size and type of hull would be best to drop this motor in? Would it be overkill in a bad way for anything close to 30"? I'd possibly want to save it for a hydro build in the future of that size, but am still very new to marine RC setups and could really use a bit of direction here.
I know I could always run it on less cells or prop it up/down to get it to work in many applications, but I suppose I'd most like to run it in an ideal setup well matched with the hull and components.
With the motor's max rating of 120amps, would I be fine with a Seaking/Turnigy T-180 speed control to power it on no more than 6s?
Also, who/where sells an appropriate motor mount for this beast?
Thank you for any and all help!
-Jeff
-Jeff
