View Full Version : Drive dog pin snapped
Mtwinste
08-11-2011, 08:20 PM
Well I was all pumped about installing a new X445 prop and when I tightened the nut the drive dog pins snapped so no running for me.
Is there a replacement pin available or should I buy an entirely new aftermarket flexshaft and drive dog?
LarrysDrifter
08-11-2011, 08:28 PM
Is this a drive dog with a roll pin? If so, just buy a new drive dog with a set screw and use that.
Mtwinste
08-11-2011, 09:02 PM
Do I need to notch flat the shaft so that the allen screw in the aftermarket drive dog has something to bite into? Seems it will slide on a round shaft
RTR Racer!
08-12-2011, 02:51 AM
I'd just buy a new shaft, the stock proboat one won't last long with that prop on it. Btw larry you spelled Neu wrong in your sig. :beerchug:
Mtwinste
08-12-2011, 08:07 AM
There's so many shafts on OSE. WHICH one should I get?
sailr
08-12-2011, 09:22 AM
What size shaft was it that the pin snapped on? The Hughey shafts use the pins. The Octura shafts use a drive dog with setscrews and YES you should file a flat on the shaft for the drive dog setscrew. I prefer the Octura shafts but have to resort to Huey's when I need .187 long shafts.
ron1950
08-12-2011, 09:40 PM
The proboat stiletto uses prob the same pin in there's if u need the stock part
08-12-2011, 11:04 PM
Here I th dog
http://www.offshoreelectrics.com/proddetail.php?prod=oct-oc6dmm
I'll have the entire cable/shaft setup tuesday.
Mtwinste
08-12-2011, 11:16 PM
Ordered that today. Which drive u order?
