View Full Version : 28.7mph on 2S
Mtwinste
08-11-2011, 09:47 AM
Glassy water. Running 40C 2S in series. Calc with Garmin GPS. Run time 8:00 with stock prop.
New props should be in this week as well as two 3S cells. I'll see if she melts and makes it to 40.
28.7 is granny.
Rumdog
08-11-2011, 10:13 AM
Put a real prop on it
v-spec
08-11-2011, 11:45 AM
You can get into the 40's easy with just a prop swap and not burn it down. It will more likely than not burn up on 6s before long and if you go any bigger than the stock prop it will for sure soon enough. it won't be much faster than 4s with the right prop either. Make sure you get a video of it though cause it'll be cool for a little while.
Racer944
08-11-2011, 11:48 AM
V-Spec... what do you recommend for a stock setup running a pair of 2s (i.e. 4S) setup? I am looking for a bit more speed, but really want to stay reliable.
Eric
v-spec
08-11-2011, 11:52 AM
Eric I'd run an x445 on it, with the stock setup it should run pretty good. A grim 42x55 will run nice too.
08-11-2011, 05:32 PM
28.7mph on 2S...Running 40C 2S in series...This is confusing, if the packs are in series then you are NOT running on 2S but on 4S. I doubt that the ESC would turn on with just 2S.
Saying "40C" tells us nothing useful. We also need the cell capacity to know much of anything about your packs. The brand helps too, some are well known to be over-rated. Like 40C/3300 mAh Turnigy 'nad-tech.
Mtwinste
08-11-2011, 05:35 PM
running TWO 2S in series. 40C 5000MAH. Deans Connectors. Always balanced. Crappy Orion Lipos
08-11-2011, 05:45 PM
running TWO 2S in series...Yes, that is 4S (14.8 volts) not 2S (7.4 volts). On the slow side for 4S as others have stated. The packs are not the reason you're relatively slow, but they probably do knock 3-5 mph off the speed compared with newer, higher quality cells.
Mtwinste
08-11-2011, 05:49 PM
Slow b/c of stock prop, but gives newbies an idea of what she'll do bone stock.
08-11-2011, 07:11 PM
I didn't mean to imply that there was something wrong, this is apparently a pretty nice boat. It is wise of ProBoat to use a mild stock prop to avoid overheating by newbies running for too long. Actually 29 mph isn't bad at all for a stock RTR.
stadiumyamaha
08-11-2011, 08:47 PM
I got 38.3 out of mine running 4s with a x442 and i havent had time to set it up yet. Still doing a lot of bouncing.
Mtwinste
08-11-2011, 09:00 PM
Wow can't wait to put my 445 on It!
Make-a-Wake
08-11-2011, 10:12 PM
M445 or x640..............
RTR Racer!
08-12-2011, 02:44 AM
Mine didn't run good with an m445 but it ran good on an x445. I've got a cut down x447/3 on it right now will see how it does.
Brushless55
08-14-2011, 01:33 AM
please let us know how that one works out!!
Mtwinste
08-16-2011, 09:18 PM
Ran tonight with x445 prop and 3S2s gens ace 5300mah 45c and burned up something. Motor or ESC not sure. Motor was way hotter than esc. Oh well I didn't really care I wanted to upgrade it anyways. Recorded 44.4mph on this setup before she blew and she was running pretty loose at that time.
Brushless55
08-16-2011, 09:53 PM
what are you saying? 3S2s??
are you running two 3s packs in series or parallel??
Mtwinste
08-16-2011, 09:58 PM
Series. Stock electronics. Stock wiring. Series.
Brushless55
08-16-2011, 10:01 PM
this system is ment for 4s power the way you ran it was 6s
to much voltage with that prop possibly burnt up your esc
kookie_guy
08-16-2011, 11:00 PM
Mtwinste, you need to be more clear when you are posting. 3S2S. what does that mean? Does that mean 2x 3s packs which means 6s total? Or do you mean you ran a 3s pack and a 2s pack in series for 5s total?
Mtwinste
08-16-2011, 11:25 PM
Series. 6S total.
Brushless55
08-17-2011, 12:11 AM
Series. 6S total.
Mtwinste
08-17-2011, 09:52 AM
Neither the motor nor ESC burnt. It thermaled bc it ran fine later on.
I bought a leopard 4074 1400kv and a seaking 180A today and will run on 6s
Brushless55
08-17-2011, 11:41 PM
good to hear about the motor and esc doing ok!
try a different prop on the stock setup while running 4s
you will like it..
Mtwinste
08-18-2011, 08:37 AM
Ran the x445 on two thunder power 2S 65C 6600mah in series. 43.4mph. Ran the batteries dead and the motor batteries esc everything was hot and even a little smoke came out from inside the hull!!!! Let it cool some and tried another pair of 2S packs and she was thermalled and wouldnt go over idle. New ESC and motor are on the way.
Brushless55
08-19-2011, 11:03 PM
this is a solid setup from Proboat
sounds like your looking to see smoke on every run :bash:
Rumdog
08-19-2011, 11:08 PM
So you ran 6s on the stock setup. Probably did significant damage to the motor and esc, and then ran 6600mah packs till DEAD?! All I have to say is....WHY?
Mtwinste
08-28-2011, 04:03 PM
50mph on 6S but very windy and sketchy. Seaking 180. Leopard 4074 1400kv. Gens ace 6S total in series. X645 prop.
Mtwinste
08-28-2011, 08:20 PM
Tried again and got 54.1mph.
Mtwinste
08-28-2011, 08:43 PM
http://www.youtube.com/watch?v=H8bou2O_dNc
Mtwinste
08-29-2011, 09:06 PM
EXACT same setup. X447 was 4mph faster than the X445. Temps were comfortable 120F
Mtwinste
X447 54mph. X445 50mph
