View Full Version : turnigy 180amp esc
fastblack
08-06-2011, 05:42 PM
hello i have the turnigy 180amp marine esc from hobbycity.com its the same sold under hobbywing seaking 180amp here on OSE. my question is i have a castle hydra 120amp HV esc in DF33 i run 1400kv leopard 4074 at 8cell with x440 prop it made the caps on esc little hot so i solderen on 2 extra caps 1000uf on + and - battery leads. it made temps on esc go down alot and the caps on battery leads had same temp as the ones on esc.
i tried the same with my turnigy 180amp esc it did not work at all the esc caps were still very warm and the extra caps was ice cold , tried other caps also same result it dont look like the extra caps is doing any work here... what is wrong????
lectriglide
08-06-2011, 06:28 PM
Some pics may help. It should have the same effect as the 120 if done properly. Many on here have done it including myself with good results. I have actually soldered the leads onto where the existing caps are on the board. Many threads on the board about how to do it.
