View Full Version : pro boat stiletto l40 x 57 prop opinions
Piranhafreak
08-01-2011, 08:36 PM
What does everyonething about running the grimracer l40 x 57 prop on a stock stiletto ? i tried the 40 x 52 and seemed to make no difference im hoping this will change that i will then likely change the esc too
dana
08-01-2011, 09:43 PM
L40/57 won't work well. It's a lifter prop for hydros or riggers
Piranhafreak
08-01-2011, 10:40 PM
what would be the ideal prop i would have thought the tunnel hull would be close to a hydro
Driggs
08-02-2011, 05:56 PM
What does everyonething about running the grimracer l40 x 57 prop on a stock stiletto ? i tried the 40 x 52 and seemed to make no difference im hoping this will change that i will then likely change the esc too I've used a 40x57L , and a 42x55 2 blade, and a x440 3 blade,, for me the x440 3 blade is the best, I run 4cell and 5 cell, but I found that the 42x55 2blade was the best for speed and seems to be safe for the electrics and heat buildup when running on 4cell, also run on low timeing , there is a big difference in speed from stock with the 42x55, I've tested this while raceing other stilettos
dana
08-02-2011, 06:20 PM
a tunnel and a hydro are so completely different. if anything a tunnel is more like a catamaran, but not really. i was also gonna suggest the 42x55 and the x440/3.
Piranhafreak
08-02-2011, 09:25 PM
WELL I HAD THE3 PROP SO i tried it it was alot faster but couldnt get up and going i had to give it a push or a full throttle punch and it was nasty but had a very hard time getting up and going not a good choice
Piranhafreak
08-02-2011, 09:28 PM
so i pulled everything out of the stiletto and installed it into a shockwave hehe lets see how that goes i now plan to build the stiletto up i just need to figure out what the biggest motor i can fit in that outboard is
CHIEFY_44
08-03-2011, 04:24 AM
i run a p220 on mine everything standard bar for the prop runs great too
