View Full Version : What wattage output does the 1518,1520,1717 Castle motors have?
crrcboatz
08-01-2011, 01:37 PM
Help appreciated.
08-01-2011, 05:35 PM
No one can tell you, that depends on the load and the voltage. Electric motors will keep producing watts until they burn up, you load them and they will keep producing power. Castle says a maximum of 25 volts input and 120 amps, so that is about 2550 watts as the recommended output for all three motors - for car use.
crrcboatz
08-01-2011, 05:55 PM
Guess I was looking for something like many of the other makers put out, ie leopard.
LarrysDrifter
08-01-2011, 06:36 PM
You said you wanted output of the Castle motors you mentioned.
Brushless55
08-01-2011, 09:10 PM
Kinda like Fluid said, Castle states 120 amps at 25.2Volts
so upto 3024 watts, but they can produce more like Fluid said...
http://www.castlecreations.com/products/neu-castle_motors.html
but there is also torque to consider with a bigger motor :thumbup1:
crrcboatz
08-01-2011, 10:17 PM
I was only hoping someone had information on them like Leopard produces on theirs printed out like leopard does theirs.
m4a1usr
08-01-2011, 10:33 PM
Help appreciated.
Castle lists the motors MAX wattage rating for those motors. http://www.castlecreations.com/products/neu-castle_motors.html But you have to half that to get the continous rating assuming they are as efficient as NEU motors. Which they are not, BUT they are certainly closer to NEU's motor ratings then anyother manufacturer out there. The rest are far below no matter what anyone states. Even Neu doesnt state they have a 90% eff motor rating, yet many of their motors do indeed test past that level. But the cheapos have no problem making such claims using far inferior components.
John
LarrysDrifter
08-01-2011, 10:35 PM
Wasnt meant to be a smart remark. I was confused. Sorry. No hard feelings.
08-01-2011, 10:48 PM
I gave you the info you appear to want in my post above. Castle does not list the max wattage on their site, just the max input volts and max amps recommended. That is all that the 'sainted' Leopard site does, except you said you wanted the output watts. For that you have to factor in motor efficiency, which I did for you in the post above.
Brushless55
08-01-2011, 10:54 PM
Geeze, chill out dude, shouting at other posters is not necessary. You write confusing posts then get mad at folks who are trying to help you? Get mad at yourself.
BTW I gave you the info you appear to want in my post above. Castle does not list the max wattage on their site, just the max input volts and max amps recommended.[/ That is all that the 'sainted' Leopard site does, except you said you wanted the output watts. For that you have to factor in motor efficiency, which I did for you in the post above.
that's what I was thinking, thank you for clearing that up..
crrcboatz
08-01-2011, 11:01 PM
Thank u larry. I will remove my remarks aimed at u from the earlier post they were out of line!:tiphat:
Not knowing how to figure this stuff like u guys did in the earlier posts puts some of us dummies at a disadvantage. tnks for all the input!
08-02-2011, 09:50 AM
well said. All the leopard numbers do is muddy up the waters. the only real way to match them would be if you had them all and tested them all using the same parameters.
