MHZ mystic C5000 44 props
  • jjrctech
    • Feb 2011
    • 162
    Ran my MHZ mystic C5000 44" for the first time has some streeing problem with the Hydraulic dummies with cable having play but everything esle good
    6s on twin 1527 Neu 1250kv 5017/3 prop motors and ESC ran at 99f-109f
    What would be the next size prop to go with for higher speed??
    --> 54" fountain - Bonzi boat. http://www.youtube.com/watch?v=_cxR6yDRJXw
  • obrien008
    • Sep 2009
    • 132
    I am looking to do a similar setup, if you dont mind me asking where did you buy the hull from?
    • ManuelW
      • Oct 2010
      • 756
      Hello,
      what speed are you aiming at and how fast is it at the moment? Personally I think these 1250kv motors on 6S each may have a bit too less rpm so you need quite big props to achieve higher speeds. Maybe a pair of 5019/3's would work? I've never run the 44" Mystic from MHZ, but what I can tell from other twin cats of that size using props larger than 50-55mm had some negative influences on the hull. Escpecially when decreasing the throttle too fast it made them unstable.
      Best regards,
      Manuel
