View Full Version : G. Finlay 1/16th scale Hydro
billf1973
07-31-2011, 09:56 PM
56828
Hello,
I am having a hard time getting my hydroplane to run correctly. It is powerd by a 3300kv, Esc is a seaking 90amp, Prop is a 1.34x2.06, and a 2s 3300mAh 30c lipo. The boat wants to go, but when full throttle is applied the front of the boat dives down. I have lowered the stuffing box about a 1/4in since it was level with transom. Still get the same result. Any help would be Great.
Thanks,
Bill
Diegoboy
07-31-2011, 10:04 PM
can you post a transom pic?
billf1973
07-31-2011, 10:15 PM
Diegoboy,
Here are a few pics of the transom.
Thanks,
Bill
568295683056831
Diegoboy
07-31-2011, 10:18 PM
How much strut angle is there + or - ? Where's the center of gravity? and What size prop is that?
billf1973
07-31-2011, 10:23 PM
Not sure of angle. I know it is about 1/4 inch between stuffing box and bottom of hull. CoG is up in front of motor where lipo goes, and its a 35mm prop.
Diegoboy
07-31-2011, 10:25 PM
Can you take a profile picture of the transom please?
billf1973
07-31-2011, 10:27 PM
That is 1/4 inches down at transom.
Diegoboy
07-31-2011, 10:31 PM
http://www.modelpowerboat.com/images/attitude/strut01.jpg
Strut angle: A strut has a positive angle when the prop shaft points upwards, far from the water surface. In this situation, the transom is pressed down. A negative angle occurs when the prop shaft points down, towards the water surface, raising the transom. If you imagine the boat supported on a transverse shaft that goes exactly through the CG, it's easy understand that, when the transom is lowered the bow goes up, reducing the wet area. The contrary occurs with a negative angle for the strut. Although apparently we could use the strut angle to correct any incorrect attitude, the truth is that the neutral angle is the ideal, just a few degrees off are allowed to adjust the wet area. If more than 2 degrees are necessary, something else should be wrong.
billf1973
07-31-2011, 10:38 PM
May be more then 1/4in.
568325683356834
Diegoboy
07-31-2011, 10:40 PM
Does she run a solid prop shaft?
That seems to be too much negative angle
billf1973
07-31-2011, 10:41 PM
No its a flex shaft .130
Diegoboy
07-31-2011, 10:42 PM
Level that prop angle first.
Heath M
08-01-2011, 05:55 AM
Try setting ur strut the same depth as the sponsons with about 1 degree of negative angle. Also straighten the rudder to 90 degrees, it's got way to much negative angle.
billf1973
08-03-2011, 01:12 PM
When I first set the the strut it was level with the bottom of the hull(touching the hull). After running it for the first time I knew the prop needed more down angle. Moved the prop down and tried it again, same results.
billf1973
08-03-2011, 01:13 PM
I will be changing rudder angle and prop shaft soon. Thanks guys!
U1Racing
08-03-2011, 02:07 PM
i knew that the strut angle was it just fro reading your original post, keep us posted on how it works out!!
electric
08-03-2011, 10:47 PM
Not sure how much experince you have, but as I read through the thread no one mentioned whether you had hit the throttle hard and held it. A lot of hydro's tend to bury the nose on take off, but if you hold the throttle down they come out of the nose dive and go. You probably know this, but just in case you have never run a hydro before I thought I would throw that into the conversation. The other method is to kind of toss it in the water going forward as much as possible and then hit the throttle.
U1Racing
08-11-2011, 12:17 PM
i knew this, but i have a scale Karelsen hull hydro and it did the same thing, i know what your talking about though, notice in the first post he said: "at full throttle". just to throw that out there
JimClark
08-11-2011, 03:04 PM
Where is the CG located when you are running?
billf1973
08-17-2011, 09:02 PM
Ok guys,
I think the problem is solved. The strut is down more added a better prop and KABOOM, it took off like a bat out of hell! Need to seal hatch better got some water in there today. When finished I will upload video.
Thanks for All your Help!
Heath M
08-17-2011, 10:10 PM
no probs, glad it got sorted out and ur happy :)
billf1973
09-09-2011, 08:21 PM
Hey Guys,
Here is a video taken today.
L4WYLB_35-I
Jesse J
09-10-2011, 09:21 AM
Sounds like it isn't quite letting loose, did you hit full throttle? What prop were you using in the vid? That thing should be ripping!
billf1973
09-10-2011, 10:01 PM
Have a big prop on now its a x438 and that was only 1/2 to 3/4 throttle. Going to change prop to a smaller one.
Jesse J
09-11-2011, 10:14 PM
I have a y535 I had s/b for me specifically for the one I had (that was my first FE build ever). If you want it let me know, it's in the for sale pileon it's way to the swap shop.
billf1973
09-12-2011, 10:08 PM
This is my first scratch build also....How much did you want for the y535?
billf1973
09-07-2013, 12:06 AM
I have learned over the past few years that brushless boats need at least a 4 pole motor. There was a 2 pole motor in this boat.
