View Full Version : how would i run 2 4s packs on this boat and still be safe
arp1500
07-31-2011, 09:17 PM
i would like to now how to run the 2 4s packs in parallel
Connect the red wire of each battery to the red on the esc. Same goes for black wires. You need to make some connectors
lenny
07-31-2011, 09:35 PM
Go to OSE home page, Than to RC boat links, Than at top of page is Tips & INFO , look in batteries tips & info.
Than go to Q & A SEARCH FOR 5.5 Y connectors or Y deans connectors,
Go and do search in charger & battery info.
arp1500
07-31-2011, 09:36 PM
lenny that link isnt working
arp1500
07-31-2011, 09:37 PM
dana so i need to cut the wires and make some connectors
how is the boat wired now? wire color wise
lenny
07-31-2011, 10:02 PM
Sorry:sorry:
Look again at posts,
arp1500
07-31-2011, 10:10 PM
ok ill try it now
arp1500
07-31-2011, 10:23 PM
ok i think i might of figured out my setup
what do you all think
proboat impulse 31 deep vee: http://www.proboatmodels.com/Products/Default.aspx?ProdID=PRB4250
castle creations connector: http://www.rcplanet.com/Castle_Creations_Parallel_Conc_p/cse011-0006-00.htm
2 4s 4500 lipos not sure what c rating yet
Mtwinste
07-31-2011, 10:39 PM
Won't doing so destroy the stock electronics? Today I ran two 3S on stock setup and it thermalled after about 3-4 min
lenny
07-31-2011, 10:45 PM
Look at my post info.
You want to go up 5.5, Can you solder to make 5.5 y ?
Cells 30c or 40c IMP.
lenny
07-31-2011, 10:50 PM
You need to run cells in parallel not series or:flammes-09::flammes-09::flashfire::doh:
v-spec
08-01-2011, 01:00 AM
This is what you need to make. http://forums.offshoreelectrics.com/showthread.php?23833-5.5-Bullet-parallel-conectors
arp1500
08-01-2011, 08:42 AM
ok so you guys dont recomemend using the deans connectors
why do they melt
arp1500
08-01-2011, 08:51 AM
what lipos do you recommend
lenny
08-01-2011, 10:47 AM
Yes.
Good lipos, Gens ace or Turnigy 30c to 40c, 3000mah and up, I use soft packs 4s 40c to 50c 5000mah
Check out the testing hear,http://forums.offshoreelectrics.com/showthread.php?25172-Diesel-Battery-Testing
v-spec
08-01-2011, 11:32 AM
For the money Gens ace.
lenny
08-01-2011, 11:39 AM
:iagree:
Brushless55
08-01-2011, 01:09 PM
why do they melt
Deans can take 60amp cont. I think, where as Bullet connectors can take much more amps
this is what I did to run deans on my SV27 boat running parallel packs
I soldered the back leads of the connector and placed this on one side of the stock series wiring on the esc
http://i703.photobucket.com/albums/ww39/filmmaker2009/012-3.jpg
and these are my parallel connectors for bullet packs
http://i703.photobucket.com/albums/ww39/filmmaker2009/005-9.jpg
arp1500
08-01-2011, 03:39 PM
brushless 55,
looks good
is it needed 2 run bullets because everything else i have is set up with deans 5 battery packs, 2 chargers, 4 trucks
so how is the inside of th eproboats wired..
would i have to cut off the stock deans and re wire that also or just make a adaptor
arp1500
08-01-2011, 03:40 PM
does anyone have a pic of the inside of the boats with the wires exposed
electric
08-01-2011, 04:23 PM
Let me take shot at explaining the series/parallel thing. Forget connectors for just one moment and lets just talk wiring.
1. Parallel. Take the red wire from battery one and connect it to the red wire coming out of battery 2 and then connect that to the red wire going to the esc. Repeat the same thing for the black side. Now you have two batteries connected parallel. Same voltage, but twice the MAH's.
2. Series Now this looks weird, but I promise it will not blow up. Plug a red wire out of battery one, into the black wire of battery two. Now, take the red wire from battery one and hook it to the esc, and then take the black wire from the battery two to the esc. You have now doubled the voltage, but same MAH.
With bullet connectors, one connector per wire comming out of the battery, here is how I hook it up series.
1. Plug the red wire of battery one into the black wire of battery two.
2. Plug the red wire of battery two into the esc.
3. Plug the black wire of battery one into the esc.
4. Ready to go.
Might help you picture how it works better...
Brushless55
08-01-2011, 04:51 PM
not sure if these pictures will help, but here is a 4s2p setup using 4 2s packs
http://i703.photobucket.com/albums/ww39/filmmaker2009/004-15.jpg
http://i703.photobucket.com/albums/ww39/filmmaker2009/006-14.jpg
http://i703.photobucket.com/albums/ww39/filmmaker2009/008-5.jpg
lenny
08-01-2011, 05:23 PM
Wiring diagrams in OSE tips & info,http://www.offshoreelectrics.com/info-pages/serial-parallel.php
