View Full Version : Impulse on 3S what do I need?
Mtwinste
07-31-2011, 01:32 PM
I want to run the impulse 31 on two of these batteries: max amps Race Edition LiPo 6500 3-cell 11.1v.
What motor and ESC will I need to run these batteries after I burn up the stock stuff using them?
v-spec
07-31-2011, 02:08 PM
You need around a 13-1500kv motor and a 6s esc like swordfish 240hv or hydra ice 200hv. If you haven't bought those packs already I wouldn't waste my money. Your better off with some cheap turnigy or gens ace packs.
Mtwinste
07-31-2011, 02:33 PM
Too late already ordered them.
Why can't I use the stock 1800kv motor?
Which ESC you recommend getting?
Mtwinste
07-31-2011, 02:35 PM
Nevermind. I see you named them. Thanks!!
dana
07-31-2011, 03:30 PM
You can use stock motor, just be prepared to blow it up. 6s on that motor = 39000 rpm. That's too much for anything more than 1 minute or so tops, and even then it's way to much. Your target rpm should be 25000- 35000 rpm
