View Full Version : I got an Impulse, did you?
v-spec
07-26-2011, 01:27 PM
I got a new Impulse! Ordered from Horizon Hobbies yesterday morning and it's here today! Lot's of pics! All from my phone but they should be decent enough.
The boats very well put together and as much as I hate to admit it MUCH better put together than my Motley Crew.
The hardware is solid and pretty nice for an RTR and everythings sealed up on the transom as you will notice in my pics. The battery trays are a little narrow for my lipo's but they will probably fit, it's a pain in the neck getting to the screws for the turn fins to install them because of the swim step. Without having ran it I'd have to say at least from a quality point of view it's the best RTR to date. Enjoy! :Peace_Sign:
56427 56428 56429 56430 56431
v-spec
07-27-2011, 06:50 PM
more pics!
56432 56433 56434 56435 56436
v-spec
07-27-2011, 06:51 PM
And More!
56437 56438 56439
lonneyb
07-27-2011, 07:37 PM
Our first shipment of them is arriving on friday!...Cant wait!
v-spec
07-27-2011, 08:21 PM
Just went over the boat once more while removing the motor and esc and etc and noticed the flex shaft is VERY tight in the strut bushing, tight enough that I could not remove it by hand. Maybe it's just mine and it's VERY minor but it's something to watch out for so you guy's don't go load your motor up your first time out.
Other than that, with the hatch taped up water leaks from the swim step/transom through the silicone cooling hose because the hose is a little too small compared with the hole drilled for it, again not a big deal and I've already fixed it with an Aeromarine water inlet http://www.offshoreelectrics.com/proddetail.php?prod=aero-2014 that popped right in perfect with a small dab of silicone sealant to seal it. Here's some pics.
56446 56447 56448 56449
electric007
07-27-2011, 08:33 PM
what the top speed of this beauty!
slow-at-rc
07-27-2011, 08:46 PM
The prop shaft on mine was good but I did not check the cooling line in the transom that might be where the vary little but of warred is coming in at
v-spec
07-27-2011, 08:47 PM
I've not ran it yet but I have run this motor/esc setup in other boats. With the right prop usually in the mid 40mph range maybe a little more on 4s. It's a great setup! :thumbup:
As for the cooling line leak in the transom, it's not much but my boats are upside down a lot in our local pond since it's next to the beach and winds always blowing. I took it into the bathtub and put it upside down to check for leaks and that was the only place it was leaking (at least while it was in the tub.)
slow-at-rc
07-28-2011, 08:41 AM
I see you didn't wast any time taking all the stock ele. out. What do you plan on running in it?
v-spec
07-28-2011, 09:44 AM
I'm still not 100% sure. I know what I wan't I'm just not sure what I can afford. If I can sell some more stuff I'd like a Neu 1415 1y and Hydra Ice 240. I might have to make due with some sort of clone motor and a Seaking 180 though.
That might not be so bad but I want to run this boat in the P mono class and it's already a little small compared with the delta 33's cyberstorms and Insane 34's that are pretty common, I'd hate to be down on power as well. It's basically a delta 29 without the ride pad so it's small. Worst case I'll just have to practice driving!
I know one thing though, whatever decision I make it's going to be today because I can't wait to get it on the water!
roadrashracing
07-28-2011, 11:36 AM
Does anyone know what the the speed difference is between the 1500 and 1800 motors? I kind of want one of these but kind of what to know so speeds, I don't run lipos.
v-spec
07-28-2011, 11:48 AM
The 1800kv is a couple mph faster with the same props. I've had both motors in other boats numerous times and that's been my experience. You will have to buy the program card if you don't have it already to set the esc to run nimh without it hitting the LVC early.
roadrashracing
07-28-2011, 11:51 AM
I am just looking to see if it would be faster then my stock spartan with the same batteries.
v-spec
07-28-2011, 12:54 PM
Probably a little faster.
One thing I just realized and had to grab the boat to check out and make sure was that the tupperware cover to keep everything dry is pretty useless with the cowl lock design since there is a big hole to let all the water in. I tape my boats anyways but for those of you who don't (why wouldn't you?) it's one more reason to buy some hockey tape.
56534
07-28-2011, 01:22 PM
56534
Good CATCH!
ron1950
07-28-2011, 02:13 PM
kinda says u better tape it up or else .....someone forgot to check that part out lol....how does the hatch go on anyway? i thought i saw a small hole for a pin in the front like the geigo hatch ..so what is the big hole in the back for?
v-spec
07-28-2011, 02:46 PM
Ok guys I'm bored so it's time for me to start posting some of my plans for the Impulse. Before I do though let me first say that this boat doesn't really need anything besides some 5.5 bullet connectors found here http://www.offshoreelectrics.com/proddetail.php?prod=ose-55bullet for the motor and esc/batteries a roll of hatch tape and some water to drive it in. It really is that nice!
With that said, I bought this boat to make it fast. It will be modeled after the P class boats and that mean's 4s and whatever I can fit under the cowl. My tight budget will narrow down my motor and esc choices as well as batteries since I sold my awesome Thunder Power 4s packs to pay for the boat.. I'm going to be ordering some parts as soon as I make a final decision (again since the last Neu 1415 1y sold here on OSE as soon as I decided to pull the trigger :frusty:) for now I've got an empty hull begging for power!
56537
slow-at-rc
07-28-2011, 02:51 PM
kinda says u better tape it up or else .....someone forgot to check that part out lol....how does the hatch go on anyway? i thought i saw a small hole for a pin in the front like the geigo hatch ..so what is the big hole in the back for? its a hatch lock
v-spec
07-28-2011, 10:51 PM
Well I ordered a couple motors and an ESC and a bunch of other little stuff today. One cheap motor to hold me over till my Neu comes in! This is what I got.
Neu 1515 1Y on order from local LHS
Tacon 4074 2150kv
HRC/OSE extra long 4074 water jacket
Castle 6.5mm bullet connectors for motors
Castle 5.5m bullets for batteries/esc
Seaking 180esc
1 Gens Ace 4s 30c 5300mah pack
2x Thunder Power 4s 65c 5000mah packs
GT3B 2.4ghz radio and receiver
and a bunch of velcro because I had to remove the proper lipo holder to fit my packs (sorry Tony!)
I was tempted to not order the tacon motor (any of you used one?) since I've never tried one but for $49 I said what the hell since it'll get me on the water till my Neu comes in. LHS said 3 weeks or so which totally sucks. Hope it's worth the wait, actually I know it will be! The last Neu I had was in my old H&M drifter S and it hauled!
Anyways I'll post for everyone to see once I got something worth posting. In the meanwhile I removed the awesome lipo holder since my 4s packs don't fit very well and rub up against the bolt in the middle.
They technically "just" fit but they are rubbing up against that bolt pretty good pushing the pack in in the middle (hard to tell in the pics but the packs pushed in pretty good.) I'm also going to coat all the wood with epoxy since most of it is untreated. Here's some pics.
JackBlack26
07-29-2011, 12:18 AM
I have one of those Tacon 2150 motors. They are awesome! Comparable to the Castle motors with the exception of the motor leads. Great value motor. Just take it apart and check for shavings inside. I opened mine before I ran it and sure enough, it had shavings on the rotor.:doh:
v-spec
07-29-2011, 12:42 AM
Ok thanks good to know and thanks for the heads up! I was just gonna order a seaking 180 since they are in stock at hobbypartz with free shipping and only an hour from my house so I get it next day but then I saw the Tacon for $49 and the thing that made me actually order it was that it was Orange in color and matches the orange on my boat! (sucker I know!) I've still got a Leopard 2200kv too at least I can compare the two sometime.
dmwilson09
07-29-2011, 12:22 PM
Is the stock prop on the boat S/B?
v-spec
07-29-2011, 12:47 PM
No it's not but I've worked on a few of them and they are clean casts and not far off balance from the factory. It's not a prop I'd use on this boat with the stock motor myself but it def won't burn things up.
dmwilson09
07-29-2011, 12:51 PM
I am thinking about getting this boat and would like to run a prop that would get this boat up to 40 Mph on 4s with out hurting/stressing the electronics. Can you anyone recommend a prop.
v-spec
07-29-2011, 01:42 PM
An x or m445 should get you there but don't expect to run it for 10 minutes with that prop and check temps before you run too long with any prop upgrade.
slow-at-rc
07-29-2011, 01:43 PM
Octura x445
dana
07-29-2011, 02:06 PM
try a 3 blade on 5 s hehe like an x440/3 or a grim 40/52/3
dana
07-29-2011, 02:11 PM
byw i had tacon motor 1900 kv green can that died on the 6th run, but ive heard the orange cans are much better quality and more comparable to the leopard than the green ones. i wonder why tho....
dmwilson09
07-29-2011, 02:13 PM
Proboat specs the stock prop as a 1.6x2.5. So my question is (and I really dont know), wouldnt a m or x445 be a smaller prop.
dana
07-29-2011, 02:19 PM
more like the stock prop has more pitch. im not sure the diameter of that stock prop but i think the x445 is larger diameter and definitely less pitch. im not sure i agree with the prop proboat used (considering its the same one they use on all their boats) i think the 1.4 series would be a better choice given the motor. jmo
v-spec
07-29-2011, 09:42 PM
The stock prop is 41mm
v-spec
08-02-2011, 05:01 PM
New packs are charging! Should be on the water with my new boat today! Hopefully my camera girl shows up to make a video if all goes well!
Rumdog
08-02-2011, 05:56 PM
lets see it!
v-spec
08-03-2011, 01:01 PM
Ok I got to run the boat a few times before it got dark. It still needs a fair amount of adjustments but it should all get sorted out without too much trouble. (I hope!)
First off, it's really fast! I can't stay on the throttle until I get the boat setup better. I wanted a video so I could come home and watch it to see what it needed as far as adjustments since I didn't have much time at the pond before dark yesterday. Everything is nice and cool after the run all below 90 after 1 minute. ESC was 86 battery 89 motor was 83. Not bad considering it was 81 degrees outside.
I had a stuffed it on another run and somehow cracked the hatch pretty good. The way the foam flotation is on the hatched caused it to crack everywhere except where the foam was placed. Oh well $30 more to horizon. Anyways it's a great boat and it should run really nice once I get it dialed in. http://www.youtube.com/watch?v=b-2gZDZ0duY
