View Full Version : minicatracing hydro problem,,,
electric007
07-25-2011, 11:57 PM
just put my mini cat in the water for the first time today. it ran 10mph.. running 11.1 3s 25c jens ace
also pickup alot of water. and now its just .....jittery.... the prop just does a twitch.. help someone. what should i do its new and the first time i put it in the water. very upset... what do i need to do to make this thing move 40mph like it suppose too..
electric007
07-26-2011, 12:50 AM
no one can help.. wow this is just wounderful.
skellyo
07-26-2011, 08:21 AM
Did you check the water cooling for leaks?
Did you completely tape up the hatch?
Did you set the endpoints on the ESC before you ran?
What radio system are you running?
Did you program the ESC with the programming card? What setting did you use?
Also, because you have problems with it now after getting the electronics wet, you should let them dry completely before attempting to test it again.
electric007
07-26-2011, 09:45 AM
Traxxas 2.4gz. Receiver. Recommend setting for the esc. Yes no leaks the hatch was not tape complete Cause was just running it for test in my pool. Tryed it again today esc sparked and a little smoke came out. Does this mean everything is fryer now. And will a Turnigy 60amp esc be to much.
Doby
07-26-2011, 10:02 AM
By not taping the hatch, you probably killed your electronics. Water in a pool is just as wet as water in a lake. An expensive lesson.
electric007
07-26-2011, 10:32 AM
Will the motor be still good. Or should I replace that too
ron1950
07-26-2011, 11:30 AM
motor is prob still fine......
