View Full Version : higher rpm vs bigger prop
jjrctech
07-25-2011, 09:36 PM
Is it better to run bigger props or smaller prop and higher Rpm for high speed runs???? I think a smaller prop setup would be better at speed higher then 60mph ?? wanted to ask before I test it out.
obrien
07-25-2011, 09:38 PM
Depends on the hull and overall setup of the boat.
jjrctech
07-25-2011, 09:47 PM
Small C5000 33"
drwayne
07-26-2011, 09:49 AM
I ran 36" Maritimo twin @49k rpm unloaded
LR ABC1616/3 = 80+mph
LR X442 = ~74mph
check signature for clip.
Simon.O.
07-27-2011, 05:34 AM
There is a minimum dia prop for many hulls, I know as I have tried small props with insane rpm on many of my hulls and have varied success.
There comes a point when the prop is too small.
From here I go up in size with a X4 prop and then try the X6 props I have too. Then comes the rpm and I get to mix it all up with a combination of pitch and rpm.
fwiw my rebuilt rigger will run a lot of X4 props before the X6 ones go on, and consider this is running a 1600kv Outrunner on 6S. Minimum prop size for this hull is 437 or 637, either way it is 37mm.
