View Full Version : 1717 or 1520
Brushless01
07-18-2011, 04:16 AM
Hi guys just ordered one of the flood hulls from Aeromarine laminates, what i was wondering is which motor to run ? i have already have purchased both motors. Also does anyone know what motor mount will work ?
My goal is too have good speeds in the high 50's
Thanks
Brushless01
07-18-2011, 05:24 AM
Would this mount work ? http://southriverrcboats.com/shop/article_WRP-4-25FLA/WRP-4%22-Rail-Front-only-mount-25mm-hole-pattern.html?shop_param=cid%3D83%26aid%3DWRP-4-25FLA%26
skellyo
07-18-2011, 08:23 AM
One of these would work better than just a single endbell mount:
http://fightercatracing.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=118&category_id=22&option=com_virtuemart&Itemid=1
http://fightercatracing.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=123&category_id=22&option=com_virtuemart&Itemid=1
Fightercatracing.com is closed until Wednesday this week though so you won't be able to order from them until then.
Brushless01
07-18-2011, 08:37 AM
Thanks which motor do you think would work the best and give the higher top speed ?
steveo
07-18-2011, 09:11 AM
both motors will get in the 50's like you wanted i think then its a matter which will do it eaiser, i only own a 1520 and am about to pull the trigger in a 34" cat on 5s i think i should get 50 or close to and in an MM you should be able to break into the 60's with the smaller hull, there is a thread in the boat building section of someone using a 1717 in an MM
carlcisneros
07-18-2011, 09:32 AM
Bushless, I use the lower motor mount from fightercat that skellyo listed there.
works great.
Brushless01
07-18-2011, 09:59 AM
Thanks guys do you think that the 1717 and fightercat mount will fit under the modern cowl ?
skellyo
07-18-2011, 10:21 AM
Check out this thread regarding a MM with 1717:
http://forums.offshoreelectrics.com/showthread.php?23641-Project-Mean-Machine-Castle-1717-on-6s&highlight=1717
Brushless01
07-18-2011, 12:41 PM
Thanks guys prop recommendations ?
LarrysDrifter
07-18-2011, 01:27 PM
1520 on 6s with an X445 to start and you'll be happy.
Brushless01
07-18-2011, 01:38 PM
Thanks but im most likely to use the 1717 as the 1520 is setup in my truggy.
Rumdog
07-18-2011, 04:02 PM
1717 is wasted energy in that boat. Way too much power.
Brushless01
07-19-2011, 02:58 AM
ok thanks im going to go with the 1520 and fightercat mount and a Seaking 180.
