millzee
07-15-2011, 11:35 PM
Here's a link to the build so you can see the set up(save me typing it all)
http://forums.offshoreelectrics.com/showthread.php?26294-Mean-Machine-cheapy-nitro-conversion&highlight=
I first tried with a m447 on 4s and it ran around 35mph, 5 minute run and the temps were cold, through it back out for another 5 minutes and got bored, bought it back in and the lipo's still had what I'd guess to be another 5 minutes in them, it'll be great for the kids althought it does take a bit to get it up out of the water from a stand still.
I then through in 2x 6s and kept the m447 on, it got out of the water a lot better and handled ok but I only got 63kph-39mph. After a few runs with the m447 I switched over to a x548 which caused a lot of bounce so I soon changed again up to a x450 which was a big improvement but still a long way from where the goal is, the x450 has awsome pick up, almost top speed from a standing start but the top speed is still only 78kph-48mph, temps are only 40C all around after a 3minute run, and after a few runs with this prop and trying a few different battery placements, I found that with my batteries back at around 28.5-29.5% cog, the boat had a little bit of bounce and couldnt corner at too quicker speed without causing a roll over or flip. With the batteries moved 1/2 inch forward, it ran more settled but it lost a couple mph in top speed:confused2: . I have increased the adjustability of the strut and have the bottom of the strut set to approx: 5-6mm above the bottom of the sponsons and have it set at around zero angle. I'll have some footage once I can get around to cutting out all the boring stuff. Can anyone offer some advise to help me get more speed out of her??:help: Also, I had a lot of glitching with the rx/tx, I'm guessing I'll need to put the antenna outside the hull, this is the first issue I've ever had with the dx3s system, would it just be the carbon cloth in the hatch blocking the receiption?:help:
