View Full Version : outrunner on OB lower unit
carlcisneros
07-10-2011, 07:32 PM
Getting ready to set up an outrunner on a lower unit and before it hits the water for the first time in a couple weeks or so,
would Corrosion X be ok to spray into the motor before it runs the first time?
thanks
:help:
Rumdog
07-10-2011, 07:46 PM
Absolutely. Afterwards dry it well with compressed air if you can, and reapply corrosionx.
carlcisneros
07-10-2011, 08:28 PM
Thanks Rummy, will do just that.
LuckyDuc
07-10-2011, 10:47 PM
ACF-50 is a better choice. http://www.corrosion-control.com/pcproducts/acf-50.htmlf
HOTWATER
07-10-2011, 11:03 PM
Carl, I just spray it in the motor, shake it out a bit and let it dry for a few minutes before running again, that's all...you will be fine!
lohring
07-11-2011, 12:45 PM
We've been running both inrunner (P spec) and outrunner motors on outboards for several years. Even WD-40 sprayed into the motors keeps them running. Our current inboard setups leave the motor exposed for cooling. Water doesn't seem to be a big problem with motors. I will be running in salty water soon so I'm not sure how well these precautions work in bad conditions.
Lohring Miller
carlcisneros
07-11-2011, 09:21 PM
Lohring;
I know what running nitro motors in salty water does to them.
keep PLEANTY of wd-40 on hand and some good light weight oil ready to spray the heck out of them after EACH and EVERY run.
